wheel weights
Old Dec 31, 2006 | 11:18 AM
sam0218's Avatar
Default wheel weights
so im gonna paint my steelies pretty soon, but i have noticed that there are wheel weights. i dont want to paint over them because if they ever get removed there will be a spot that hasnt been painted. so 1 question is how do i remove them, and the second question i have is, when i go get new tires and what not can they put the weights on the inside of the wheel? thanks in advance
Old Dec 31, 2006 | 12:36 PM
vtecsi00's Avatar
Default Re: wheel weights (sam0218)
yes the weights can be put inside if you like.....to get them off we use a special weight puller at work...but if i remember right you can use a something with a pointed flat edge and a hammer and tap it in between the weight and wheel and it should come loose enough to take it off with a pair of pliers
Old Dec 31, 2006 | 01:39 PM
old man neri's Avatar
Default Re: wheel weights (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">but if i remember right you can use a something with a pointed flat edge and a hammer and tap it in between the weight and wheel and it should come loose enough to take it off with a pair of pliers</TD></TR></TABLE>
But will he be able to get them back on?
Old Dec 31, 2006 | 02:26 PM
sam0218's Avatar
Default Re: wheel weights (old man neri)
they were easy to pop off with a screwdriver and a hammer. and i wont be putting them back on, i will have the tire place whoever they may be put them back on only on the inside, when i get new tires cuz mine are basically slicks
Old Jan 1, 2007 | 12:11 AM
vtecsi00's Avatar
to old man neri...yes he could have with a hammer tap it back on if he had chose to....but he wasn't planning on
Old Jan 1, 2007 | 02:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">to old man neri...yes he could have with a hammer tap it back on if he had chose to....but he wasn't planning on </TD></TR></TABLE>
Good to know.
Old Jan 1, 2007 | 08:36 PM
vtecsi00's Avatar
your welcome old man neri....I aim to please
unspankable
Aug 1, 2012 12:19 PM
OoHiTzToMMy
Jun 13, 2007 11:40 AM
Don Jefe
Jan 11, 2006 12:31 AM
taunt_spike
Sep 25, 2005 02:26 PM
ViZ
Jan 3, 2004 08:47 PM
