wheel/lowering advice needed!
Old Nov 30, 2009 | 02:42 PM
heyimrchills's Avatar
Icon3 wheel/lowering advice needed!
i was wondering what you guys think i can get for 400-500$ for a good set of wheels
and was also wondering about cambering and the def of "slammed"/lowered and how to have a good offset and make everything look nice
as much info/ref to sites about these topics always needed!
thanks.
Old Nov 30, 2009 | 06:25 PM
H22Ej1's Avatar
Shenanigans
Default Re: wheel/lowering advice needed!
400-500 can get u a clean set of used rotas/konigs with tires or a new set w/o tires just check the marketplace, and your in socal so im sure ull be able to find something nice. cambering the wheels allows you to go lower essentially tilting the tire inward, but can also cause excessive tire wear when it becomes more extreme.
Old Nov 30, 2009 | 06:33 PM
Mikesvx&accord's Avatar
I suggest not tilting the tire inward too much, in the long run It is not worth the tire cost and it puts alot of excessive stress on various other things making it harder and harder to align your car properly as time goes by.
Old Dec 1, 2009 | 11:31 AM
H22Ej1's Avatar
Shenanigans
a little amount of negative camber is actually preferred. the care handles more aggressive into a turn and if the toe is zeroed out the wear due to camber is negligible.
90% of the tires with wear referred to as camber wear is in fact due to the misalignment of toe. Toe out of spec destroys tires, camber generally only increases the wear slightly.
Old Dec 1, 2009 | 02:03 PM
DrZFiNeSt's Avatar
For that price you can get a used set of Rotas.What kind of car do you have because that will help us give you the right info on what offset to run.
Old Dec 1, 2009 | 02:42 PM
black02em2's Avatar
i like rotas for that reason, reasonable prices for decent lookin wheels
Old Dec 5, 2009 | 07:51 PM
Si Trav's Avatar
yes and no. just be careful where you drive your car. rotas arent as durable as your OEM wheels
Old Dec 5, 2009 | 08:33 PM
H22Ej1's Avatar
Shenanigans
that is not true. in all of the rota wheel failure pictures/posts ive seen the wheels were put in a situation where any wheel would have failed. in my experience rotas hold up just as well as higher priced wheels. infact numerous autocrossers use rotas as their track wheels because if they get chewed up theyre a cheap replace and they hold up to the conditions just fine
Old Dec 6, 2009 | 05:56 PM
Post Re: wheel/lowering advice needed!
i have a white acura integra 98
Old Dec 6, 2009 | 06:14 PM
H22Ej1's Avatar
Shenanigans
anything in the +35 to +40 offset range will be fine and stockish
vdub08
Aug 9, 2010 09:06 PM
alex_s817
Mar 25, 2006 09:43 AM
sackdz
21
Oct 1, 2003 12:59 PM
itr1235
Jul 12, 2003 03:24 AM
DB2-R81
10
Aug 29, 2001 01:12 PM
