What wheel setup for the track?
Old Apr 6, 2016 | 09:55 PM
EG Jake's Avatar
Default What wheel setup for the track?
Building an eg for the track, but not exactly sure what the best setup would be for the tires. I was thinking of going with 15x8's and 215/50 or 225/50 tires, but I'm not sure what offset would be the best to give the most clearance and least rubbing issues. I'm going to be running 12k (672) front springs and 8k (448) rear springs so rubbing shouldn't be that much of an issue.
Old Apr 6, 2016 | 10:04 PM
toyomatt84's Avatar
Sanji
Default Re: What wheel setup for the track?
Were you planning on widening the panels via either a fender roller or flares?
Old Apr 6, 2016 | 10:18 PM
EG Jake's Avatar
Maybe just a little fender roll. Want to keep my car as mint as possible, only have 80k miles on it. Might even be down to do 45/15's.
Old Apr 7, 2016 | 10:12 PM
toyomatt84's Avatar
Sanji
Will you be using a camber kit?
Old Apr 8, 2016 | 12:23 AM
EG Jake's Avatar
Yea I will be, not sure how much camber ill be running though. Dont want to buy too big of a tire and be limited in my camber settings.
Old Apr 8, 2016 | 10:08 PM
toyomatt84's Avatar
Sanji
A 225/50 could fit, if you're okay with a little negative camber.
Old Apr 8, 2016 | 10:47 PM
EG Jake's Avatar
What offset would you recommend for a 15x8?
Old Apr 9, 2016 | 11:15 PM
toyomatt84's Avatar
Sanji
No lower then +35.
2000SIKILLER
Jun 27, 2013 11:52 PM
94VTEC2TONE
May 23, 2011 01:41 PM
wannaBjdmca6
Nov 25, 2010 10:01 AM
Dubs13
Aug 13, 2008 10:48 AM
warwagon
Jun 2, 2006 09:42 AM
