What size
Old May 3, 2006 | 05:57 PM
turnsignalandy's Avatar
Default What size
I have an ek lowered on tein s techs. Should i go for 15 or 16 in rims. Would the tires on the 15 last longer and would i run the risk of rubbin on the 16?
Old May 3, 2006 | 06:54 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What size (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">I have an ek lowered on tein s techs. Should i go for 15 or 16 in rims.</TD></TR></TABLE>
You can go either way. The 16" rims tend to be more expensive, and so are the tires that go on them. But a lot of folks prefer the looks of the 16" rims. Your choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">Would the tires on the 15 last longer</TD></TR></TABLE>
No, they should last roughly the same amount of time, assuming they're the same model tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">would i run the risk of rubbin on the 16?</TD></TR></TABLE>
Rubbing is a function of the size of the tire and the offset of the wheel. If you get the proper offset wheel, and use the proper size tire, you should not have any rubbing. The proper size tire for your car is 195/55-15 or 205/50-15 on 15" wheels, and 205/45-16 or 215/45-16 on 16" wheels.
Old May 3, 2006 | 07:32 PM
Default Re: What size (nsxtasy)
what offset should i use for 16s?
Old May 3, 2006 | 09:12 PM
nsxtasy's Avatar
H-T Order of Merit
Well, I know it depends on width; you would probably want 16x7 rims. Beyond that, I don't know; maybe someone here is familiar with the '96-00 Civic and can answer.
riyakhan
Aug 3, 2007 12:54 PM
polyestercheez
Mar 3, 2006 08:03 AM
db8geezer
Jan 22, 2006 04:48 PM
98-0688
Aug 21, 2004 03:28 PM
Ditdogs
Mar 23, 2004 08:23 AM
