upgraded tires
Old Mar 23, 2006 | 07:45 AM
tomy_r's Avatar
Default upgraded tires
alright thanks for looking, i am wondering if i can upgrade my tires from 175 to 195 or so. i have 14 inch steelies and currently is running 175/55?/14 sumitomo srixons. i was wondering if the steel rim will be able to fit 195? the thread walls are too thin and cant hold the corners too good. i drive a 92 eg-4dr, i put the 14 on there when i bent a rim on the 13" inch set. anything will help
tomy_R
Old Mar 23, 2006 | 08:26 AM
nonsense's Avatar
Default Re: upgraded tires (tomy_r)
I ran 195/60-14 Azenis Sports on by 14" steel wheels.
Old Mar 23, 2006 | 08:29 AM
nsxtasy's Avatar
H-T Order of Merit
You can use 185/60-14 on a Civic ('95 or earlier) without any problems. It has about the same outer diameter as the stock tires.
If you want better performance, get a better tire in that size. The Yokohama ES100 is a very good tire and it's available in 185/60-14. The Falken Azenis RT-615 will be available in 185/60-14 starting this summer.
195/60-14 is too big. It will throw off the speedometer and odometer, will make your acceleration slightly slower, and could rub on the wheel wells.
Old Mar 23, 2006 | 11:39 AM
nonsense's Avatar
Default Re: upgraded tires (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">195/60-14 is too big. It will throw off the speedometer and odometer, will make your acceleration slightly slower, and could rub on the wheel wells.</TD></TR></TABLE>
He is correct, for the EG it's too big. I should have noted that the EK runs bigger tires, but as for as width goes, yes 195 will fit on that rim.
Stock 92-95 Civic DX comes with 175/70-13
Stock 96-00 Civic DX comes with 185/65-14
175/70-13 = 22.6" diameter
185/60-14 = 22.7" diameter
185/65-14 = 23.5" diameter
195/60-14 = 23.2" diameter
So you see that your EG won't really like the larger overall diameter of the 195 tire unless you run a 195/55-14. I know that Dunlop SP 8000's come in that size, and they're $80/tire
Old Mar 23, 2006 | 02:58 PM
tomy_r's Avatar
the yokohomas are at a fairly decent price,isnt it? thanks a lot, i am gonna save some money and invest in some good tires for my steelies, do you know any good places on the net where you can get these performance 185/60/14.
Old Mar 23, 2006 | 03:40 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomy_r &raquo;</TD></TR><TR><TD CLASS="quote">the yokohomas are at a fairly decent price,isnt it? thanks a lot, i am gonna save some money and invest in some good tires for my steelies, do you know any good places on the net where you can get these performance 185/60/14.</TD></TR></TABLE>
You can get the Yokohama ES100 in 185/60-14 for $67/tire at the Tire Rack (click here).
Old Mar 23, 2006 | 03:46 PM
tomy_r's Avatar
thnaks a lot
Jswike
Jan 14, 2013 04:15 AM
Whatislove
Jan 20, 2012 11:43 AM
Torontodude
Feb 11, 2008 10:11 AM
kdawgy2k1
Jan 12, 2006 06:45 PM
M-EJ1
Apr 8, 2003 08:30 AM
