Tread depth question
Old Jun 1, 2005 | 09:03 AM
95TEG's Avatar
Default Tread depth question
My tires are down to 2/32, and I dont know alot about tires. They are worn, but dont look too bad. Do I need new tires based on this tread depth? Thanks for any feedback.
Old Jun 1, 2005 | 09:56 AM
eMpAtHy's Avatar
Default Re: Tread depth question (95TEG)
2/32
how far do you want to ride ur tires down to?? the steel belt?
to ansewr your question, yes, you need new tires.
Old Jun 1, 2005 | 10:19 AM
95TEG's Avatar
Default Re: Tread depth question (eMpAtHy)
I wasnt sure. Thanks.
Old Jun 1, 2005 | 10:21 AM
Neo79Si's Avatar
In states that have extensive vehicle inspections, your car will not pass inspection with only 2/32" of tread. The tires may still ride/handle ok in the dry...but any water on the road will make things interesting in a hurry. As empathy said, it's time for new tires!
Matt
Old Jun 3, 2005 | 01:12 AM
romJones's Avatar
Default Re: Tread depth question (Neo79Si)
yup
if your treadwear is at 2/32...def time to replace...
you'll have slicks in no time if u run those tires anymore
you can also check by looking within the grooves of the tire...
there is something called a "tread bar"...
which is automatically set on all passenger tires at 2/32
once the tread bar is flush with the useable tread...
time to replace
btw...fyi...passenger tires come with 10/32 useable tread brand new
Old Jun 3, 2005 | 05:35 AM
95TEG's Avatar
Default Re: Tread depth question (romJones)
Thanks for all the input
JCritt
Apr 7, 2006 12:31 AM
Cosworth
Apr 29, 2003 02:02 PM
crazy_ham
Feb 11, 2003 10:24 AM
Sohc Driver
Feb 8, 2002 07:06 PM
F120man
11
Sep 4, 2001 02:10 PM
