tires size help
Old Feb 17, 2007 | 12:43 AM
Cream's Avatar
Default tires size help
will 195/60/15 tires fit on a eg civic hatch without modification or hammering the fender?
Old Feb 17, 2007 | 07:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tires size help (Cream)
No, absolutely not. Those are HUGE! (Over an inch and a half larger diameter than stock, almost 7 percent larger.)
For your '92-95 Civic, stick with 195/50-15.
Old Feb 17, 2007 | 01:28 PM
vansterdam's Avatar
You want to stay within 3% of your stock tire diameter, otherwise you mess with brakes, suspension and your speedometer & odometer. For cars with ABS, this could cause major problems as these computers use assume your tires are stock height.
Here's a good tire calculator to compare tire specs.
Old Feb 18, 2007 | 02:15 PM
Cream's Avatar
Default Re: tires size help (vansterdam)
thanks for the help
Whatislove
Jan 20, 2012 11:43 AM
jdmitrdc2
Mar 18, 2009 12:49 PM
99hondacura
Mar 2, 2009 03:20 PM
chotchkie
Mar 30, 2004 07:09 AM
zk11
Oct 8, 2001 01:42 PM
