Tire help
Old Feb 8, 2006 | 11:20 PM
lucidvtec's Avatar
Default Tire help
i need to know what tires i can run
i'm about to get the 5zigen fn01r-c 15x7 in black with polish
i want to run drag radials in the front and regs in the back
also i wanna run as fat as a tire in the front without rubbing and decent turning
i have a full omni power suspension setup i would like little wheel gap
so can i run these tires in the front
http://www.tirerack.com/tires/...ace=1
they are a 235/60R15
and the rears i wanna run
its a 205/55R15
will this tire setup fit the 15x7 rims?
will it look good?
will i be able to lower it?
will it rub bad?
what is ur 15" TIRE setup?
plz let me know ASAP
i'm trying to order ASAP
i'm runnin some lame 14's on a 300whp+ integra....and ya that lame
I NEED TRACTION
thx
Old Feb 9, 2006 | 07:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire help (lucidvtec)
Are you using these just for the dragstrip only, or do you plan to use them on the street?
If you're looking for tires to use on the street, then get a set of four Falken Azenis RT-615 in 205/50-15 and call it a day. It's the stickiest tire you can get that is designed for street use. No rubbing. They should last around 10K miles on an Integra (vs 3-5K with drag radials). Perfect for 15x7 wheels on an Integra. $78/tire at Vulcan Tire or Edge Racing.
Old Feb 12, 2006 | 03:10 PM
lucidvtec's Avatar
it's for a daily driver
i decided on going with 225/50R15 in the front..the BFG drag radials
and in the rear..i'm going with 205/50WR15...the BFG kdw t/a 2's
i know i will have to replace the drag radials alot...but from i heard its the next best thing compared to slicks....i will roll the fenders...i'm not lowering the car too much...hope the fronts don't rub too bad
Old Feb 12, 2006 | 05:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (lucidvtec)
With drag radials on the front, and budget performance tires on the rear, your car is going to oversteer big time. Don't be surprised if you find yourself going around a turn and the back end comes around on you.
BTW, the KDW2 is really overpriced. Heck, for the price of a pair of KDW2's, you can get four of the Dunlop Direzza DZ101 in 205/50-15 from Edge Racing ($45/tire there, vs $58/tire at the Tire Rack). They're just as good and less than half the price. You can also get the similar Yokohama ES100 or Kumho SPT for a lot less than the cost of the KDW2. All these tires offer very very similar performance. No need to spend more than you have to for the same performance...
garyc17
Oct 8, 2010 09:27 AM
lucidvtec
Feb 9, 2006 11:09 AM
Ben Ogle
Aug 18, 2005 07:31 AM
crookedletterd
Jul 23, 2001 10:04 AM
