Tire balancing? Alignment? Help...
Old Aug 26, 2006 | 05:08 PM
B7AudiA4's Avatar
Default Tire balancing? Alignment? Help...
I've searched, but nothing came up helpful for me.
I had rims and my steering wheel was fine... It didn't shake or very minimal shaking. I had my alignment done not too long ago, like 2 months ago I suppose
I put on my stock tires today and had them balanced before I put them on, but now my steering wheel shakes when I drive at 40+ speed.
Is this caused because my balancing was not done correct?
Thanks in advance for the help if any.
Old Aug 26, 2006 | 06:03 PM
vtecsi00's Avatar
Default Re: Tire balancing? Alignment? Help... (FutureITR)
have the shop rebalance your tires and wheels .......normally if it only shakes at certain speeds and goes away at higher or lower speeds it a balance issue!!!!!!!
Old Aug 26, 2006 | 06:32 PM
B7AudiA4's Avatar
Default Re: Tire balancing? Alignment? Help... (vtecsi00)
I was thinking that might be the issue. Hopefully everything works out and they agree on rebalancing them again.
If that's correct, then I think that's the problem. Thanks.
Modified by FutureITR at 10:33 PM 8/27/2006
Old Aug 26, 2006 | 10:31 PM
vtecsi00's Avatar
Old Aug 28, 2006 | 08:34 PM
B7AudiA4's Avatar
Got it done today. Balancing was done right.
When I had rims on, I had some spacers. And for some reason 1 spacer was stuck on the brake portion and had it checked out. Everything runs fine now, thanks for the input vtecsi00
Old Aug 29, 2006 | 03:44 PM
vtecsi00's Avatar
your welcome
sd619jef9
Nov 5, 2011 10:14 PM
exz0n-.-
Nov 27, 2008 12:19 AM
Nizzy
Aug 21, 2003 07:31 AM
gina
Nov 20, 2001 04:36 AM
