slick size???
Old Jul 16, 2008 | 12:49 PM
stanzione88's Avatar
Default slick size???
Hello i would like to know what slick size should I run... b16a with intake and full exhaust, but will go turbo in 6 months and will like to use the same size for both setups. I will keep the wheel size 13.
opinions please
Old Jul 16, 2008 | 01:10 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: slick size??? (stanzione88)
How do you plan to use these? Only on the dragstrip? Or also on the highway to and from the strip? And daily driving? What about the racetrack? Autocross?
Old Jul 21, 2008 | 06:00 PM
only at the dragstrip. no autocross.
thank you.
Old Jul 21, 2008 | 06:58 PM
H22Ej1's Avatar
Shenanigans
how much power do you plan to put out after boost?
with a stock b16 na id rock a 22"
Old Jul 22, 2008 | 10:00 AM
nsxtasy's Avatar
H-T Order of Merit
If you don't get a good answer here, you might try asking in the Drag Racing forum, where there is a lot more expertise with dragstrip-specific questions. Good luck.
Old Jul 22, 2008 | 12:54 PM
i will make around 300whp on boost since i want to stay on the safe side.
Its a stock motor with arp headstuds.
thank you
Old Jul 23, 2008 | 10:39 PM
H22Ej1's Avatar
Shenanigans
if uve got the b16 trans and planning for 300 whp id get 24.5x8's that way your trap speed will be higher and it will lengthen your gearing a tad to keep you out of 5th
jmonee112
Jun 14, 2007 04:35 PM
Bevin
Sep 8, 2006 04:45 AM
RZbltCRX
Feb 1, 2006 04:41 PM
HONDASPANCHO
29
Sep 12, 2005 06:27 AM
lsvtec4door
Mar 9, 2003 03:44 PM
