replace one tire or two?
Old Mar 11, 2007 | 02:13 PM
TooStock's Avatar
Default replace one tire or two?
Well, I hit a huge pothole with the driver front tire and now I have this golf ball sized bubble on my sidewall. This pretty much means I have to replace it, right?
My question is should I replace both the front tires or can I get away with just replacing the bad one? Am i gonna get uneven wear and see more problems with only replacing one as opposed to two?
For reference.. the current set was installed 10/05.
Old Mar 11, 2007 | 02:18 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: replace one tire or two? (TooStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TooStock &raquo;</TD></TR><TR><TD CLASS="quote">Well, I hit a huge pothole with the driver front tire and now I have this golf ball sized bubble on my sidewall. This pretty much means I have to replace it, right?</TD></TR></TABLE>
Right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TooStock &raquo;</TD></TR><TR><TD CLASS="quote">My question is should I replace both the front tires or can I get away with just replacing the bad one?</TD></TR></TABLE>
As long as you're replacing it with the identical size and model, you can just replace the one tire.
Old Mar 11, 2007 | 02:23 PM
TooStock's Avatar
Default Re: replace one tire or two? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Even though the other three have over a year of wear on them?
Old Mar 11, 2007 | 02:27 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TooStock &raquo;</TD></TR><TR><TD CLASS="quote">Even though the other three have over a year of wear on them?</TD></TR></TABLE>
Yes.
However, if the other three are so worn that you are going to replace them soon, and you think you would like to replace them with some different make/model of tire, you might want to do two or even all four now, with that other make/model.
VTECdohcter
Dec 7, 2007 03:26 PM
aznryd3r
Jan 23, 2006 03:20 PM
metal-x
Apr 26, 2005 02:37 PM
AzntaggeR
Sep 3, 2003 02:27 PM
b20turboic
Aug 10, 2003 07:01 AM
