REMOVING PAINT FROM WHEELS??
Old Sep 12, 2007 | 08:14 PM
chinoty's Avatar
Default REMOVING PAINT FROM WHEELS??
Anyone knows if AirCraft Paint Remover will work on power coated rims?? If not, does any know what would really work??
Old Sep 12, 2007 | 09:14 PM
chinoty's Avatar
Default Re: REMOVING PAINT FROM WHEELS?? (chinoty)
Some ones got to know.. I know for a fact it takes off paint. I've used it several times. Just not sure about powder coating??
Old Sep 23, 2007 | 07:17 PM
chinoty's Avatar
bump bump
Old Sep 25, 2007 | 06:32 AM
r.wright's Avatar
yes it will. try it and use it preferably in hot/warm weather(well ventilated) and let it sit for a good 15mins..basically just follow the directions. i like the spray type best but you may want to buy a few cans depending on the amount of area you are using it for .
Old Sep 25, 2007 | 08:16 AM
A lil 2.3l action's Avatar
Default Re: REMOVING PAINT FROM WHEELS?? (Opossum Jenkins)
yes itll work....but what do you plan on doing with the wheels when your done cuz you cant just use aircraft stripper and then be done with it.....you either have to repaint them or use a good bit off clear coat or they'll get ruined
Old Sep 25, 2007 | 08:44 AM
r.wright's Avatar
Default Re: REMOVING PAINT FROM WHEELS?? (A lil 2.3l action)
he is right and especially since most factory finishes have a thick primer underneath that may be scratched or uneven....afterwards, you will need to sand off all the factory primer ether if you want to polish the wheels or if you want to paint then use another coat of primer then base, etc
Old Apr 24, 2008 | 01:08 PM
TypeSJess's Avatar
will this process work with wheels on the car? and will it affect the tires?
Old Apr 25, 2008 | 05:40 PM
EJ8CIVIC's Avatar
Default Re: (TypeSJess)
aircraft paint remover
i got 4 1 gals at my house hehehehehe sniff sniff
Old Apr 25, 2008 | 07:17 PM
-JAWSHUA-'s Avatar
for sure. i swear by that stuff. always have some in my garage
ghosthatch
Paint and Body
Nov 23, 2012 08:01 PM
S2kGuy07
Honda S2000
14
Jun 12, 2007 12:34 PM
mrnewguy
Aug 19, 2006 10:36 AM
SRd240sx
Oct 30, 2005 06:30 PM
conesmasher
May 9, 2003 10:12 PM
