quick ? bout lug nuts
Old Aug 3, 2007 | 06:04 PM
buymesomedunks's Avatar
Default quick ? bout lug nuts
i read somewhere that u cant use rays lug nuts on factory wheels. ive seen some on usdm ITR wheels so is this true?
Old Aug 3, 2007 | 06:33 PM
r.wright's Avatar
Default Re: quick ? bout lug nuts (buymesomedunks)
oem rims use ball seats and most/if not all after market wheels use conical.
u can use them but your wheels will not seat correctly...beware/
Old Aug 4, 2007 | 06:45 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buymesomedunks &raquo;</TD></TR><TR><TD CLASS="quote">i read somewhere that you cant use rays lug nuts on factory wheels.</TD></TR></TABLE>
Stickied at the top of this forum, where it's easy to see unless you're really clueless , is a topic called
Forum Rules and FAQ - READ BEFORE POSTING.
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">What lug nuts do I need?
The "seating area" (or "seat") is the area of the lug nut, and the area of the wheel, that come in contact with each other. Stock Honda/Acura wheels have a ball/radius/spherical shaped seating area, and need lug nuts (such as stock lug nuts) which also have the same shaped seat. Aftermarket wheels use a tapered/conical/cone shaped seating area and need lug nuts (including most tuner lug nuts) which also have the same shaped seat. No, it is not safe to mix and match (stock wheel with tapered lugs or vice versa); the contact between the lugnut and the wheel will be insufficient, putting undue stress on them and potentially causing failure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buymesomedunks &raquo;</TD></TR><TR><TD CLASS="quote">ive seen some on usdm ITR wheels so is this true?
I've seen a lot of people do stupid and unsafe things with their cars. It's quite possible that you've seen it. It's still stupid and unsafe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">oem rims use ball seats and most/if not all after market wheels use conical.
you can use them but your wheels will not seat correctly...beware/</TD></TR></TABLE>
except for the text messaging abbreviations.
Old Aug 4, 2007 | 10:50 AM
r.wright's Avatar
Default Re: quick ? bout lug nuts (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
hey. i was referring to my clueless friend. his name is U.
is3oo
Aug 19, 2008 06:14 PM
boosted.CRX
Jul 13, 2006 12:45 PM
99_dc2
Feb 21, 2006 01:05 PM
.BigSexy
Feb 15, 2006 03:58 PM
bonylad
Jan 19, 2006 05:57 PM
