Question about wheel width???
Old Jun 16, 2005 | 07:13 AM
dawrenn's Avatar
Default Question about wheel width???
I am planning on getting new wheels. I have decided to go with Rota Circuit 8's or Rota Slipstreams in 15 inch. I am confused on what width to get? I am lowered 2.5 inches.
If I get The circuit 8's in 15's which size should I get?
15 x 6.5 +18 8h x 108
15 x 6.5 +38 8h x 100
If I get slips in 15's what size should I get?
15 x 7.0 +35/+40 4h/5h x 100/114.3
15 x 6.5 +40/+45 4h/5h x 100/114.3
Old Jun 16, 2005 | 10:01 AM
Mike_C's Avatar
Default Re: Question about wheel width??? (dawrenn)
7 inches wide and +40 offset is ideal. i'm assuming this is for an ek?
Old Jun 16, 2005 | 12:21 PM
dawrenn's Avatar
Default Re: Question about wheel width??? (Mike C)
Yea, A 2 door coupe which is actually an EJ8
Old Jun 16, 2005 | 04:34 PM
Mike_C's Avatar
same thing
Old Jun 23, 2005 | 03:03 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">7 inches wide and +40 offset is ideal. i'm assuming this is for an ek?</TD></TR></TABLE>
They dont have a 7 inch wheel with a +40 offset for slipstreams.
With the Circuit 8's they only have them in 6.5 inch with a +38 offset? Would I have problems with that offset?
Circuit 10's are 6.5 with a +45 offset.
Old Jun 25, 2005 | 09:28 AM
Screaming Vtec's Avatar
I think you'll find that et45 is 'perfect' on the EK - as mr honda intended
Old Jun 26, 2005 | 01:39 PM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawrenn &raquo;</TD></TR><TR><TD CLASS="quote">With the Circuit 8's they only have them in 6.5 inch with a +38 offset? Would I have problems with that offset?</TD></TR></TABLE>
not at all.
Old Jun 26, 2005 | 01:50 PM
dawrenn's Avatar
not at all.</TD></TR></TABLE>
Even though I am lowered 2.5 inches?
What tire size should I get?
Old Jun 26, 2005 | 02:38 PM
Mike_C's Avatar
What do you do with the car? If you don't autocross or drive your car on track, I'd go the safe route of a 195/55/15. 195/50/15 is also an option, but it will lower your car even more. 205/50/15 will probably rub now and then if you don't have some ridiculously stiff springs.
Old Jun 26, 2005 | 03:16 PM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">What do you do with the car? If you don't autocross or drive your car on track, I'd go the safe route of a 195/55/15. 195/50/15 is also an option, but it will lower your car even more. 205/50/15 will probably rub now and then if you don't have some ridiculously stiff springs.</TD></TR></TABLE>
I use it as a daily driver. 195/55/15 is what I have on my Si's so if I get 15's I can just transfer them over. My springs are not really still.
TurboD1695
Dec 29, 2007 06:10 PM
Jesterian
16
Dec 26, 2006 06:34 AM
bluebullet
Jan 8, 2006 11:19 PM
Ben_si
17
Jan 5, 2005 04:18 PM
