old version of azenis??
Old Sep 21, 2007 | 02:06 PM
AutoDB8's Avatar
Default old version of azenis??
what's the difference between the old falken azenis and the new ones??? which one is better? i have two old version but new Falken Azenis 205/50/R15 thinking about slapping them on my 15" ls mesh rims.... and get two falken ziex 205/50/R15 for the other two rims or should i get azenis as well.....azenis and ziex or azenis and azenis........
Old Sep 21, 2007 | 02:14 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: old version of azenis?? (AutoDB8)
The new ones are more resistant to ill effects of overheating than the old ones.
Azenis and Azenis, definitely. No matter what you do, do NOT mix the supersticky Azenis with the crappy all-season Ziex tires. Making one end of your car grip and the other end slide is a prescription for disaster. You shouldn't have any problems mixing the old Azenis with the new Azenis, though.
Old Sep 21, 2007 | 02:20 PM
AutoDB8's Avatar
Default Re: old version of azenis?? (nsxtasy)
yea im thinking about azenis/azenis but im also second thinking cause its starting to rain now in LA..... which makes me think if i should have the azenis in the back and ziex in front for gripping on wet road or am i thinking wrongly ...
Old Sep 21, 2007 | 03:38 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoDB8 &raquo;</TD></TR><TR><TD CLASS="quote">yea im thinking about azenis/azenis but im also second thinking cause its starting to rain now in LA..... which makes me think if i should have the azenis in the back and ziex in front for gripping on wet road or am i thinking wrongly ...</TD></TR></TABLE>
Again, you are thinking wrongly. I'll explain.
First of all, I wouldn't advise getting the Ziex if you live in Los Angeles. The Ziex is an all-season tire. All-seasons are made for handling snow and frigid cold. Unless you occasionally drive to mountain areas to go skiing, you don't need all-seasons.
Most summer tires handle rain better than most all-seasons. The big exception, as you probably know, is certain summer tires which are designed to grip well on dry pavement, to the exclusion of anything else, and the Azenis is one of those tires. It doesn't do well in rain. Most other summer tires, such as the Kumho SPT, do very well in rain.
Still, you shouldn't mix the Azenis with a summer tire that does well in rain. The problem is, on dry pavement, the end of the car with the Azenis will grip better than the other end, but in rain, the other end will grip better. What you really want, to avoid this problem, is to have all your tires matching - either the same model of tire, which is preferable, or at least tires that are very similar in performance.
Either mix Azenis with Azenis, if you want the maximum traction on dry pavement, or get four other matching tires that all do better in rain, such as the Kumho SPT.
Old Sep 22, 2007 | 07:04 AM
AutoDB8's Avatar
arite thx for the advice guess imma take a chance with azenis / azenis even though its raining season coming in right now......guess ill just have to drive carefully.....
Old Sep 22, 2007 | 08:33 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoDB8 &raquo;</TD></TR><TR><TD CLASS="quote">arite thx for the advice guess imma take a chance with azenis / azenis even though its raining season coming in right now......guess ill just have to drive carefully.....</TD></TR></TABLE>
Yup. SLOW DOWN when it's raining. And not just by 5 mph.
Also remember that rain traction gets a lot worse when the tires get worn down. If you haven't already seen it, check out this test of stopping distances on wet pavement and you'll see how much difference this makes.
Old Sep 22, 2007 | 08:56 AM
AutoDB8's Avatar
yea thx for the tips ....i can always save the azenis and just use kumho spt u were telling me about..... also was wondering what happens if i leave my tires in the garage for a long time of period.........cuz if i do get the spt tires i dont think imma be using the azenis till like next summer or something........
Old Sep 22, 2007 | 09:10 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoDB8 &raquo;</TD></TR><TR><TD CLASS="quote">also was wondering what happens if i leave my tires in the garage for a long time of period.........cuz if i do get the spt tires i dont think imma be using the azenis till like next summer or something........</TD></TR></TABLE>
Click here for Tire Rack's advice on the best way to store tires.
Old Sep 22, 2007 | 11:42 PM
AutoDB8's Avatar
thx i end up getting the azenis on but i think imam get a set of spts hahaha the first rain of season is not doing so great for me with the azenis on......but thx for all the advices and tips......
Old Sep 23, 2007 | 02:24 AM
Doostur's Avatar
I have a set of the older Azenis on my stock ITR rims, i was always curious on the differences myself.
Old Sep 23, 2007 | 05:28 PM
AutoDB8's Avatar
Default Re: (Doostur)
yea so far from the stuff on here tells me some actually like the old version of azenis and not as much with the new ones....
Old Sep 23, 2007 | 07:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (AutoDB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoDB8 &raquo;</TD></TR><TR><TD CLASS="quote">yea so far from the stuff on here tells me some actually like the old version of azenis and not as much with the new ones....</TD></TR></TABLE>
Not true. The new ones are better, period. They are more resistant to heat buildup, and they aren't quite as bad in rain, either. According to Grassroots Motorsports, they turn better lap times in autocross, too.
Old Sep 26, 2007 | 07:39 PM
AutoDB8's Avatar
Default Re: (nsxtasy)
really hmm i dunno.......i guess so but so far im liking how these spts handle as well......
Dann6968
Jul 7, 2007 02:06 AM
EGTeK
Mar 17, 2003 10:08 PM
aNaRcHyiNmYeK
Apr 12, 2002 10:44 AM
CivicSiRacer
11
Oct 10, 2001 01:12 AM
