offset on a eg
Old Oct 11, 2007 | 12:51 PM
sohctodohc's Avatar
Default offset on a eg
hey i have a set of 16 inch buddclub spf2 or something like that and they have to much offset they sit in to far.
i wanna get rid of them and buy a 15 inch wheel with a offset that will set the wheel and tire right at the fender.
whats a good offset for this for a 94 civic ex coupe??? thanks for the help
Old Oct 11, 2007 | 03:40 PM
sohctodohc's Avatar
Default Re: offset on a eg (sohctodohc)
ttt
Old Oct 11, 2007 | 04:25 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc &raquo;</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">Rules</FONT>
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. <FONT SIZE="4">Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.</FONT></TD></TR></TABLE>
Old Oct 11, 2007 | 06:00 PM
sohctodohc's Avatar
Default Re: offset on a eg (nsxtasy)
welp i guess im out of bumps then
Old Oct 11, 2007 | 07:15 PM
r.wright's Avatar
do you know what offset the wheel is ? i mean anything from +38 to +50 offset will be about right depending on tire size (may cause inner rubbing)
if you go any lower than 35 offset 16x7 and your car is low then you will need either dialed in camber and/or rolled fenders..
tire size should be 195/45-16 or 205/40-16 and offset i recommend +35 - +42 for that nice look w/o having to do modifications...
Old Oct 11, 2007 | 08:36 PM
hayabusa160's Avatar
Default Re: offset on a eg (Opossum Jenkins)
15x7 35 offset is pretty nice. its not that flush but better then 40 or 45 offset.
you need to roll fenders tho if you plan to ride around low.
408wdy
Northern California (Sales)
May 14, 2008 08:05 AM
130R
14
May 31, 2005 10:38 AM
Grip
Mar 12, 2005 09:23 AM
fastwanabe
Jan 13, 2005 01:12 PM
IloveAPC
Nov 30, 2004 09:52 PM
