need help with rub issue
Old Apr 21, 2009 | 11:57 AM
EGed up from the seat up's Avatar
Default need help with rub issue
so i got some wheels their 15x6.5 with an offset of +34 on 205/50/15 tires. when i put them on my car they were rubbing. my question is, could i run a smaller tire size without having to roll the fenders and quarter panels or makin them camber ? if so what is the tire size thati should be looking at ? thanks in advance
Old Apr 21, 2009 | 12:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: need help with rub issue
What kind of car is this for? On a '92-95 Civic, you should be using 195/50-15. And yes, they will give you more clearance, in diameter as well as tread width. I can't tell you exactly which offsets will work, but with the right offsets, 195/50-15 shouldn't rub, even if your car is moderately lowered.
Old Apr 21, 2009 | 12:22 PM
its a 93 del sol and its slightly tucking from the front, so 195/50-15 should do it ?
Old Apr 21, 2009 | 03:27 PM
JNocon's Avatar
205/50/15 w/ 34 ET will rub in the front when you do TURNS. I have one too on my EG2, but w/ a 35 ET, so I switched it to 195/50/15. No more rubbing when I do turns. And no fender rolling or camber kit.
Old Apr 21, 2009 | 05:08 PM
alright then its settled, 195/50 it is ! and clean *** sol man !!
Old Apr 22, 2009 | 02:28 PM
nsxtasy's Avatar
H-T Order of Merit
195/50-15
TylerCJ7
Apr 20, 2013 01:30 PM
rexfan
Mar 16, 2007 10:31 AM
sumyungguy
Dec 14, 2005 02:28 PM
GsR-Freak
Apr 14, 2005 04:42 AM
second edition
Dec 26, 2003 10:17 AM
