hubcentric rings?
Old Aug 23, 2008 | 01:19 PM
coupej1's Avatar
Default hubcentric rings?
i have searched and couldnt find a staright answer, i have a set of 15inch rota slipstreams on my 95 civic and was wondering what size hubcentric rings i would need to get.
Old Aug 23, 2008 | 02:14 PM
It Wasn't Me's Avatar
Get rings that are 56.1mm inner diameter and 67mm outer diameter. Should fit nice 'n snug.
Old Aug 25, 2008 | 09:29 PM
.:Made in OC:.'s Avatar
Default Re: hubcentric rings? (coupej1)
I forgot what size the centerbore of those wheels are but you can measure that easily with a digital caliper or a ruler. Figure that out in mm and find the correct one that fits that and is hub centric to the cars hub bore which is a 56.1mm Any wheel/tire shop should be able to provide some cheap plastic ones which work fine.
Old Aug 26, 2008 | 07:20 AM
The hub on the car is actually 56mm. Which is why the OEM wheels have a bore of 56.1mm - so they just fit over the hub, for a snug fit.
Rota Slips have a bore of 67.1mm, which is why I suggested 56.1mm ID and 67mm OD.
Old Sep 6, 2008 | 10:03 AM
jkiser's Avatar
^^^^^It wasn't me is absolutly correct. I just got some hub centrics for my Rotas.
vdubbin
Oct 21, 2006 05:41 AM
CALM_AS_A_BOMB
Dec 15, 2005 09:45 PM
Jaydeep
Jun 24, 2005 12:48 PM
darrinbrewer
Apr 7, 2003 08:10 PM
direct_connect
Oct 6, 2002 09:02 AM
