Hubcentric Rings
Old Aug 4, 2008 | 07:34 AM
lude98SH's Avatar
Default Hubcentric Rings
Will all aftermarket wheels need to run these ? Im going to be running Rota Slipstreams. Do i need the hubcentric rings ? I know I used them with my old 5zigen wheels.
Old Aug 4, 2008 | 09:33 AM
.:Made in OC:.'s Avatar
Default Re: Hubcentric Rings (lude98SH)
Yes you will need some hub centric rings. You can get free ones from tire shops.
Old Aug 4, 2008 | 10:11 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Hubcentric Rings (.:Made in OC:.)
Don't count on getting free ones from tire shops. I've tried, without success. Maybe you've had better luck than I have.
They should be provided when buying the wheels new. When buying used, if you're lucky they will be provided by the seller. Otherwise, you'll have to look around.
Old Aug 4, 2008 | 03:24 PM
lude98SH's Avatar
Default Re: Hubcentric Rings (nsxtasy)
yea well im getting them new. However are the rings application specific or what ? I have some off my old wheels but i would imagine it would differ alot.
Old Aug 5, 2008 | 03:24 PM
supersteven's Avatar
Depends on whether the wheels have a different size center bore.
Old Aug 7, 2008 | 03:23 PM
It Wasn't Me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">are the rings application specific?</TD></TR></TABLE>
Yes. The Rota's you're wanting have a center bore of 73mm. Your stock diameter (correct me if I'm wrong) is 64.1mm
Old Aug 10, 2008 | 08:38 AM
jkiser's Avatar
Default Re: Hubcentric Rings (It Wasn't Me)
Well if the slipstreams are the same bore as subzero's then you will need 67.1 OD and 56.1 ID assuming all honda's bores are the same. I just purchased some hubcentric rings for my subzero's. I'm not totally sure but the bore on the wheels might differ in the size of the rim. Best bet is to call Rota. I have 18" wheels.
Old Aug 10, 2008 | 09:36 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Hubcentric Rings (jkiser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkiser &raquo;</TD></TR><TR><TD CLASS="quote">Well if the slipstreams are the same bore as subzero's then you will need 67.1 OD and 56.1 ID assuming all honda's bores are the same.</TD></TR></TABLE>
All Honda center bores are not the same. They are 56 mm on most Civics and Integras, 64 mm on most Accords and Preludes, 70 mm on some Legends, and the NSX and S2000 are different front vs rear.
Old Aug 10, 2008 | 02:20 PM
lude98SH's Avatar
so then the wheels dont come with the rings then ? Where would I buy them ?
Old Aug 10, 2008 | 03:01 PM
Go to a tire shop.
Old Aug 10, 2008 | 03:15 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (supersteven)
They're hard to find, unless you're getting them at the same time as you're buying new wheels. It's really, really unlikely that you'll find them at a tire shop.
This is one place that sells them.
Old Aug 10, 2008 | 04:53 PM
lude98SH's Avatar
Default Re: (nsxtasy)
is there an advantage to plastic or aluminum ?
Also does anyone know FOR SURE what size 5th gen preludes run ?
Old Aug 10, 2008 | 04:58 PM
You were wanting 15x7 5x114.3 +40 Slipstreams
Your vehicle: Center Bore: 64.1mm Bolt Pattern: 5/114.3 Thread: 12x1.5 Bolt/Stud: Stud
Edit: Have a look -&gt; http://www.livermoreperformanc....html
Modified by It Wasn't Me at 6:05 PM 8/10/2008
PowerLeg
Nov 25, 2008 09:47 PM
shortdahri
Jun 26, 2007 03:58 PM
Jaydeep
10
Jul 19, 2006 09:06 PM
96dc2
Nov 9, 2005 03:49 AM
Integra21
Jul 15, 2005 10:43 PM
