how are wheels painted?
Old Jul 22, 2010 | 04:21 PM
raverx3m's Avatar
Default how are wheels painted?
does anyone know what type of paiting process is used on the wheels that come painted from the factory?
are they dipped in paint or powdercoated or just painted and then baked?
Old Jul 22, 2010 | 05:54 PM
r.wright's Avatar
Default Re: how are wheels painted?
they are either painted or anodized. some american made wheels are powdercoated
Old Jul 22, 2010 | 06:50 PM
raverx3m's Avatar
this right here for example.
Old Jul 22, 2010 | 08:13 PM
r.wright's Avatar
most likely just painted and clearcoated. most likely some type of automated process within the manufacturer.
Old Jul 29, 2010 | 06:43 PM
raverx3m's Avatar
because when i paint mine they get chipped pretty easily.
even when i lay many coats on it they still chip very easy.
and dont look as smooth.
Old Jul 29, 2010 | 07:04 PM
r.wright's Avatar
best thing to do is get them all the way down to the metal by bringing them to a chemical stripper place then primer then sand them slightly then spray the base then clear then color sand them.
Old Aug 4, 2010 | 08:31 AM
raverx3m's Avatar
thats what i did, used wheel paint as well
self etching primer, black primer, black wheel paint and clear coat. and i still get the chips on the rim.
Old Aug 4, 2010 | 08:48 AM
88hybrid's Avatar
have them powdercoated. end all ur chip problems
Old Aug 4, 2010 | 09:18 AM
ExplodingIbaLs's Avatar
I always thought powder coating was more resistant to chipping, but not completely out of the clear from chipping due to road debris. Doesn't the powder coating process also make the wheel weaker because it heats up the wheel?
Old Aug 4, 2010 | 09:54 AM
pprowler6's Avatar
most powders only require the wheel to be baked at 350-400 degrees for 10 min. I don't really think it would effect the strength on the wheel.
Old Aug 4, 2010 | 10:28 AM
r.wright's Avatar
there are different temps most pro powdercoating shops should go by depending on the type of metal they are working with.
Old Aug 5, 2010 | 06:49 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Agreed a pro shop should be aware of this, just had a set of HRE's coated. Required ordering a special low bake powder and for the oven to not exceed 325*.
Ive been tossing the idea around of just painting my oem NSX wheels but honestly pc is less of a headache and guaranteed results. With proper attention I havent had a single set of pc wheels chip.
kobeballer96
Dec 19, 2008 10:40 PM
Jbur074
Mar 7, 2008 11:00 AM
Si4279
Honda Civic (2006 - 2015)
Nov 26, 2006 01:11 PM
xkrntamax
Mar 7, 2006 09:30 AM
Troy
Feb 25, 2002 10:18 AM
