Help with OEM wheels
Old Mar 9, 2009 | 06:37 PM
ozvena's Avatar
Icon2 Help with OEM wheels
While I am curious to know what year and model it comes from more importantly I would like to know if fits my 99 Accord LX 4 cylinder with 15x6.5 OEM wheels (I measured backspacing to be around 5.75" or 146mm).
They are 16x7, I measured the backspacing to be around 5.43" or 138mm.
http://picasaweb.google.com/ozvena/D...77726033750338
- will handling be as good or better with these rims in comparison with 15x6.5 OEM?
- since the dished center is thicker in comparison to OEM steel wheels can I bolt them with no modification using the original bolts and lock nuts that the car came with? I worry the bolts might be too short...
Interestingly, there is no such wheel for Hondas (16x7 with 4 lugs):
http://www.discountedwheelwarehouse...._Reference.cfm
http://www.fatboyraceworks.com/wheels/
I used this calculator here: http://www.1010tires.com/WheelOffsetCalculator.asp
With:
Current Wheel Specs: 6.5"
Offset: 64mm
New Wheel Specs: 7"
Offset: 49mm
And here is the result:
Inner Clearance:8mm MORE
Outer Position:EXTEND an extra 20mm
I am not sure what I am looking at...
Thanks!
Old Mar 9, 2009 | 10:35 PM
randomtask77's Avatar
Default Re: Help with OEM wheels
It's not an OEM wheel. They just put a center cap on there with the honda logo on it.
Old Mar 9, 2009 | 10:43 PM
toyomatt84's Avatar
Sanji
Those look like some old Prime wheels, with Honda center caps (as previously stated).
You'd be better off finding a lighter wheel than those, if you want to increase performance. Those wheels were heavy, because they weren't made very well. Hence why they were so cheap, even when they were new.
Old Mar 10, 2009 | 05:51 AM
ozvena's Avatar
Great, the guy lied to me!!!! They suppose to be OEM from his wife accord. I am angry!!!
Old Mar 10, 2009 | 06:02 AM
ozvena's Avatar
The wheel with inflated and worn out 205 tire on it is 41lb...my 195 tire, somewhat worn out is 16lb. So the rim must be < 25lb (41 minus 16).
I need to remove the existing wheel with the winter tires to see how much it weights but I feel that it will be much less than 41lb.
I was really looking for wheels to use for summer as long as they perform as good as the OEM steel or better. I assume these wound not perform as good as OEM steel, right? Once I weight the OEM I can see for myself, I guess.
Old Mar 10, 2009 | 12:02 PM
toyomatt84's Avatar
Sanji
A good rule of thumb:
If the wheel weighs around the same amount as it's height, then it's a decently light wheel. (ex. 16" wheel weighing 16lbs)
I wouldn't be surprised to see those Prime wheels weighing around 20 or so lbs. They're pretty bulky. I would recommend something else, as those won't outperform your OEM wheels.
Old Mar 11, 2009 | 10:58 AM
ozvena's Avatar
The gentleman who sold it to me as OEM took me for a ride. He is not a rookie as myself. I googled by his phone number and it turns to be the same guy who makes lot of money selling cars: http://www.mautofied.com/sellerprofile/10072399/
I will try to find an appropriate forum on internet and publish the story together with his name, phone number, and email to warn others from him.
Now I know what Prime means on the back of the rims. I am not going to replace my 17.7lb OEMs with these 25lb monsters. Thanks guys for your help!
x_40oz
Nov 19, 2013 11:26 AM
BobbyRodriguez
May 13, 2011 07:31 AM
Rude Awakening
Mar 10, 2010 05:40 AM
Adrian Peterson
Wheels
Jan 26, 2010 06:49 PM
iperez
Nov 6, 2006 07:16 AM
