flush offset help!
Old Jul 25, 2011 | 07:36 AM
724chris's Avatar
Default flush offset help!
okay so on this rainy day ive been doing lots of research on making my wheels flush with my fenders. basically what i am running is 15x7 +40 offset. i plan on getting extended wheel studs.what i wanted to know is what size wheel spacers would i need to get this look? tires are 195-50-15.thanks for the help and if anyone has pics of a similar setup please post pics
Old Jul 25, 2011 | 08:56 AM
alphalanos's Avatar
Default Re: flush offset help!
I have 15x7 +40 slip stream with 205 tires and 15mm spacers.
I only had the front spacer on in this pic and 195 tire, back is stock. just imagine the back wheel pushed out 15mm
just fyi this required a little fender work front and rear. mainly pulling and rolling the inside lip, not too bad. also car is on stock control arms.
Old Jul 25, 2011 | 10:11 AM
724chris's Avatar
ok i was thinking of going with 20mm or 25 mm spacers. opinions?? and ya im about to roll the fenders today!!!
Old Jul 25, 2011 | 10:18 AM
toyomatt84's Avatar
Sanji
If you're looking to run that big of a spacer, you're going to need negative camber and a fair amount of body work to clear properly sized tires.
Old Jul 25, 2011 | 11:06 AM
724chris's Avatar
i lied i just did some measuring.i think in gna go with 15mm. just prob lowere my car a lil more than the car above otherwise it should be the same.
Old Jul 25, 2011 | 11:07 AM
724chris's Avatar
do you have any close up pic of how flush it is in the front? this car is the perfect example for i have a ek hatch!
ooosorio
Honda Civic (2001 - 2005)
Oct 7, 2016 10:36 PM
ilovejdm
Honda Civic (2006 - 2015)
25
Feb 28, 2010 05:46 PM
blackbndt
Jan 3, 2010 03:59 PM
FOdoFAsho
10
Dec 25, 2007 08:39 PM
Die-Laughing
Aug 24, 2004 12:44 PM
