Extended studs/lugs
No, not as long as you can mount the wheels directly to the hubs.
It's often the case when using HIGH offset wheels - that is, with our cars and their positive offsets, wheels whose offset number is large - that you often need to install spacers to move the wheels outwards away from the car (to compensate for the high offset). That's when extended studs are usually required.
