ET offset for standard wheels
I've put new summer tires with wheels on my 1999 Civic Si. The new wheels and tires came off a 2008-2011 Hyundai Accent. The original wheel spec is 5.5Jx14 ET45 for the Honda. The Hyundai is 5.5Jx14 ET46. Will this cause any issues for the long run for safety, clearance wear and tear in the long run or anything else?
Thanks
JT
Thanks
JT
This means that the Hyundai wheels will sit just 1mm farther inside the fender than your factory wheels. As long as the back side of the spokes doesn't rub against the brake caliper, I would say you will be just fine with no long-term issues at all. What about the differences between center bores of the wheels ?
