DR-20's
Old Aug 9, 2010 | 05:54 PM
smoked08's Avatar
Default DR-20's
so i got a pair of dr-20's but they lug nuts i have on my stock wheels dont fit they are too big..what kind of lug nuts would be preferable for them?
Old Aug 9, 2010 | 06:00 PM
CHiLD's Avatar
Default Re: DR-20's
the cheap skinny lug nuts u get from autozone
Old Aug 9, 2010 | 08:33 PM
smoked08's Avatar
Default Re: DR-20's
Those fit?
Old Aug 9, 2010 | 11:54 PM
CHiLD's Avatar
Default Re: DR-20's
yeah, i had the same issue. i just had a pair of dr20's on my coupe.
Old Aug 10, 2010 | 12:11 AM
smoked08's Avatar
Default Re: DR-20's
**** bro sweet !! ima get them then thanks !!
Old Aug 10, 2010 | 08:16 AM
r.wright's Avatar
Default Re: DR-20's
first off, oem lugs have a ball seat and what you need are a conical seat.
second, as stated above, tuner lugs w/ a conical seat will fit.
Old Aug 10, 2010 | 09:56 AM
Fedtemule's Avatar
Default Re: DR-20's
first of all!... sorry for my bad english.. "im from sweden"
if its okey i just wanna borrow the thread with a question...?
im gonna buy dr-20´s to my DelSol vti "si" 15*7. And i want it to look like its stretch.. So i wonder if i can go with et10??
here i Sweden the are in et0 et10 or et40..
if the et10 works perhaps some one have pics on 15*7 et10..??
thanks.
Old Aug 10, 2010 | 10:54 AM
CHiLD's Avatar
Default Re: DR-20's
it depends on the tire size you use with your wheels, not the offset.
Old Aug 10, 2010 | 11:24 AM
Fedtemule's Avatar
Default Re: DR-20's
I know i depents on the tire..im gonna go with 175/50-15
but i wonder if i can go with the et10 or are the rub something on the inside or is it gonna stick out to much??
Old Aug 10, 2010 | 11:57 AM
smoked08's Avatar
Default Re: DR-20's
alright sweet i think ima go with lock wheel lug nuts too dont **** to get stolen .
Old Aug 10, 2010 | 01:39 PM
CHiLD's Avatar
Default Re: DR-20's
they wont be rubbing on the inside, but they will stick out just a bit from the fender and with that tire size it will surely look stretched
Old Aug 11, 2010 | 09:11 PM
UnleashedEJ1's Avatar
Default Re: DR-20's
I just got a set of these wheels and I was so pissed my purple extended lugs wont fit, I thought they might cause they fit in the holes ok but theres no room for a socket to go over them. I am useing a Gorrila open ended splined lug on them now.
Old Aug 11, 2010 | 09:26 PM
smoked08's Avatar
Default Re: DR-20's
yeah im jst planning to get some tuner ones or acorn
Old Aug 22, 2010 | 09:22 PM
smoked08's Avatar
Default Re: DR-20's
so i got some lugs from autozone like i was told either to get well i got them and they did fit but they lock nut was too big and didnt fit the dr20 hole where it snuggles and spins the lug nut it was too big and no room to fit the lock nut the only way i could tighten them was by hand but thats no use so i need some links or some recommendation on what to get ...?
Old Aug 22, 2010 | 10:02 PM
CHiLD's Avatar
Default Re: DR-20's
As u can see, mine were the type that uses a key that fits inside each lug nut instead of the outside. I dont have the lug nuts or packaging anymore so sorry i cant be more helpful
Old Aug 22, 2010 | 10:11 PM
smoked08's Avatar
Default Re: DR-20's
yeah the ones i got were different and had the lock nut with it along and when i went to go return it they didnt have any others had the same ones..
Old Aug 23, 2010 | 02:28 AM
smoked08's Avatar
Default Re: DR-20's
Well I'm planning on getting gorilla lugs will those fit the dr20s & actually tighten them well & not go over the hole?
Old Aug 23, 2010 | 09:14 PM
flushek's Avatar
One Flushin' EK
Default Re: DR-20's
Yes, i had dr20 +10 offset i was running muteki lug nuts. It looks the same as gorilla's they last long too.
dwllama
Apr 21, 2014 04:24 AM
REDEM1FTW
Aug 29, 2010 08:45 AM
chiggin
Honda Civic (2006 - 2015)
10
Apr 29, 2009 05:05 AM
nomoshing
Apr 24, 2008 07:46 AM
