ap1 wheels on crv?
Old Mar 18, 2009 | 12:59 PM
adalsteinsson's Avatar
Icon2 ap1 wheels on crv?
I got my hands on a set of 4 s2000 AP1 front wheels. I know people have put them on their CRVs in the past.
I just want to know what i need to make them fit on there properly
*i have a 2000 crv*
Thanks for all responses!
=D
Old Mar 18, 2009 | 01:36 PM
r.wright's Avatar
Default Re: ap1 wheels on crv?
crv center bore is 64mm all around. s2000 front center bore is 70.1 only thing i can think of is maybe getting a hub ring from 64 to 70mm so the wheels will fit hub centric and some tires that will work for your crv.
you may even need spacers
Old Mar 19, 2009 | 01:17 PM
^ Thats about what Ive been able to find information wise also
So I guess If I can find some 5mm hubcentric hubspacers that would work right?
Old Mar 19, 2009 | 06:42 PM
r.wright's Avatar
yes kill 2 birds with one stone.
a spacer that goes from 64mm (crv hub) to 70mm( s2k wheel) then for the rear just normal hub spacer for crv 64mm to 64mm
note: the front hub spacers may need to be custom made.
Old Apr 1, 2009 | 11:58 AM
Thanks =]
Old Jun 14, 2009 | 08:18 PM
Should I get new lugnuts for this or would the factory CRV lugs be sufficient??
Old Jun 18, 2009 | 01:21 PM
nsxtasy's Avatar
H-T Order of Merit
Whatever spacers you need, you will need for both front AND rear (since all four wheels are the S2000 front wheels with the 70 mm centerbore).
The factory CRV lug nuts have the ball-shaped seating area you need. However, it's not clear whether the length of the lugs on the hub spacers will enable you to tighten the factory CRV lug nuts on. If the lugs are too long, you will need to get open-ended lug nuts with the ball-shaped seat. See the FAQ in this forum for the part number for Honda ones.
M-benz
Honda CR-V & Element
Nov 13, 2016 07:37 PM
Heathcoot
Honda S2000
Sep 14, 2010 01:26 PM
91bluehatch
Jun 15, 2010 05:42 PM
spooniq
Honda S2000
14
Aug 12, 2005 03:08 PM
pills_PMD
Honda S2000
13
Jul 12, 2004 09:01 PM
