another tire help thread..
Old May 22, 2011 | 11:29 AM
mrbkelley's Avatar
Default another tire help thread..
the wheels are WORK VS-XX 18x8 +38 and they will be going on a TSX. there needs to be a little stretch. could someone suggest some tires please? thanks in advance
Old May 22, 2011 | 07:08 PM
toyomatt84's Avatar
Sanji
Default Re: another tire help thread..
From the Forum Rules and FAQ:
10. Do not ask about "stretching" tires onto wheels that are too wide.
All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
kriscabrera
Jan 25, 2012 06:01 PM
racerx510
Jun 5, 2011 05:48 AM
hoxsie323
Jun 1, 2011 04:30 PM
TylerLorenz
Oct 6, 2009 04:17 PM
Stewie
Dec 4, 2003 07:34 PM
