Air pressure
Old Oct 21, 2010 | 06:39 PM
michael-crxsi's Avatar
Default Air pressure
How much air pressure should you put in aftermarket wheels. This is on a 91 crx si. Is it the same as the stock air pressure that's listed In the glove box
I have two sets of wheels that are different sizes if that matters
Wheel number 1
205/40-16
Number 2
195/50-15
Old Oct 22, 2010 | 04:23 AM
toyomatt84's Avatar
Sanji
Default Re: Air pressure
The car decides the air pressure, not the wheel/tire selection. Look in your driver's side door jamb to see what your factory air pressure should be.
Old Oct 22, 2010 | 09:13 AM
nsxtasy's Avatar
H-T Order of Merit
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Tires FAQ
What air pressure should I use in my tires?
As a general rule, regardless of wheel or tire size or type, the best place to start is with the pressure recommended for your CAR, as shown in your owner's manual and on your car either on the door jamb or glove compartment door. Measure the pressure when the car has been sitting for several hours out of the sun, at the outside temperature at which the car will be used. Adjust from there in 2 psi increments as needed, based on tire wear and your preference for handling and/or ride comfort.
Do NOT set the pressure to the maximum pressure indicated on the sidewall of your tire.
Old Oct 23, 2010 | 10:25 PM
Well what is a good tire pressure for even tire wear then on the weight of a crx.
Old Oct 24, 2010 | 05:22 AM
toyomatt84's Avatar
Sanji
Old Oct 24, 2010 | 05:35 AM
cetcivic's Avatar
no one wants to hear the truth
do it the "old skool" way just pump until it goes up high enough and looks hard enough
Old Oct 24, 2010 | 07:55 AM
nsxtasy's Avatar
H-T Order of Merit
That's the worst advice I've seen posted here in a while.
The proper answer to the question is in the posts above. EXCEPT this one.
ware
Jan 18, 2009 07:03 AM
RACEPAK
Jul 12, 2008 04:27 PM
Lithel
Feb 26, 2008 02:38 PM
zach1288
Apr 10, 2007 11:32 AM
