17's on a DX
Old Jun 27, 2005 | 10:36 AM
daft's Avatar
Default 17's on a DX
I have a chance to get some pretty nice 17's for a good price.. they're Centerline Exels and they come with Falken Ziex 205/40/17 tires. My car is sitting on stock suspension right now, but i would like to drop it on H&R Sports soon... I was wondering if these will rub? or ?
Old Jun 27, 2005 | 10:39 AM
$amGD3's Avatar
Swaggylicious
my boy has 17's on his 94 ex now,they wont rub but turning will be pretty hard especially without power steering
Old Jun 27, 2005 | 10:40 AM
daft's Avatar
Default Re: (sam21)
im strong, i can handle it
thanks for the comment
Old Jun 27, 2005 | 10:44 AM
JDM-EJ1's Avatar
Default Re: (daft)
No, it will not rub. When I had my 17s (big mistake). I was lowered 3" all around, and I didn't rub, except when going around REALLY sharp turns, while going up a bump.
Old Jun 27, 2005 | 10:56 AM
rewhipple's Avatar
Default Re: 17's on a DX (daft)
i have 17's on my ex at the stock ride height and have not noticed them ever rubbing. but they diffently change the ride quality cause there is no side wall.. so if there are a lot of potholes where you live like i have then you might want to reconsider
Old Jun 27, 2005 | 11:16 AM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: 17's on a DX (rewhipple)
they might rub on turns....17's will be like installing a CRX HF motor though...Final, final drive is your wheels.
Old Jun 27, 2005 | 11:23 AM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewhipple &raquo;</TD></TR><TR><TD CLASS="quote">i have 17's on my ex at the stock ride height and have not noticed them ever rubbing. but they diffently change the ride quality cause there is no side wall.. so if there are a lot of potholes where you live like i have then you might want to reconsider</TD></TR></TABLE>
Yes, potholes are horrible for low profile tires.
My friend had a set of 18's for a year and blewout probably 3 or 4 tires. Well, one of them he ran over a piece of rebar.
I have 18s now and a 1.5" drop. Only the right one rubs, and that's only when I turn the wheel all the way to the left.
Old Jun 27, 2005 | 11:56 AM
snowman0520's Avatar
i have 17s dont like em taht much anymore, and wont make the same mistake next timeits gona be 15s or just stock
Old Jun 27, 2005 | 12:02 PM
vsmhatched's Avatar
Default Re: (snowman0520)
yeah I made the mistake of 17's but 15's are in the future with me....At first it hard to turn without power steering
Old Jun 27, 2005 | 12:28 PM
civic_tj's Avatar
Default Re: (GreyDel)
I have 17's on mine with the exact same tire and I personally don't like it. I love the look but the ride is hell around these parts. One of my friends has 16's with a 205/45/16 same tire and i like his better, not but much but still better. I feel his handles better too but we also have different suspension set ups also.
full_race_eg6's Avatar
17's work but if you want to be safe just get some 16x7 then your good.
Old Jun 27, 2005 | 01:13 PM
Neighborhood Superstar's Avatar
Default Re: (sam21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 &raquo;</TD></TR><TR><TD CLASS="quote">my boy has 17's on his 94 ex now,they wont rub but turning will be pretty hard especially without power steering</TD></TR></TABLE>
well your BOY must be weak. I have 17x7.5 on my 93 hatch with no rubbing issues.
just make sure you get the right offset and youll be alright.
Old Jun 27, 2005 | 11:10 PM
daft's Avatar
Default Re: (=Gameover=)
another question... is there anything that i should check about the used wheels and tires? is there anything i can check to make sure they're in good condition?
Old Jun 27, 2005 | 11:45 PM
daft's Avatar
Default Re: (daft)
bump
Old Jun 28, 2005 | 04:06 AM
JDM-EJ1's Avatar
Default Re: (daft)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daft &raquo;</TD></TR><TR><TD CLASS="quote">bump </TD></TR></TABLE>
Why are you bumping it? People have told you that it won't rub, even when they're 3" lower.
Old Jun 28, 2005 | 06:43 AM
rewhipple's Avatar
Default Re: (daft)
the obvious thing to check for is cracks. some of the other things that you may want to keep in mind. Lots of ding and scraps on the wheel could mean that the wheel has been repeatedly bounced of curbs or that it has hit a pothole hard enough that the might not be true anymore.. not saying this is the case but i have heard of it happening.. safe thing to do if a visual inspection does not yield any warning flags would be to take the wheels to a tire shop in have them unmount the tire and check the wheel for its trueness...
Old Jun 28, 2005 | 07:10 AM
Snail Tuning's Avatar
17s will work on a civic. but they get camber wear, because of the size, and can rub on turns, and make a very harsh ride. if you have an auto the extra weight and mass and make the life span of your tranny shorter aswell.
Personaly i think 17s on a civic is just plain old stupid. my brothers 92 DX hatch had them, and it looked out of place, like a 4x4 and they had bad camber wear all around. stock everything, and it was aligned.
Old Jun 28, 2005 | 07:24 AM
jolt-tsp's Avatar
Default Re: 17's on a DX (Snail Tuning)
Like a lot of other people here it seems, I made the mistake of 17's. Don't need them if you car is &lt;2500lbs I think. The heavier, the bigger brakes you may want, so you'd have to up the wheels. Also, big wheels don't look sexy on a civic like they do on a vette or bimmer or something.
Old Jun 28, 2005 | 07:25 AM
Earthworm Jim's Avatar
Default Re: (daft)
Stock height they look fine, I don't know why would lower them at all. There might be a half inch of space but That's good cool. Make sure they are woren down evenly before you by them. Lay down onyou're stomach and see how they sit. If they lean, it might be alright just take some off the price.
Old Jun 28, 2005 | 08:14 AM
-Darren-'s Avatar
go for it man.
Old Jun 28, 2005 | 10:04 AM
daft's Avatar
Default Re: 17's on a DX (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">Like a lot of other people here it seems, I made the mistake of 17's. Don't need them if you car is &lt;2500lbs I think. The heavier, the bigger brakes you may want, so you'd have to up the wheels. Also, big wheels don't look sexy on a civic like they do on a vette or bimmer or something.</TD></TR></TABLE>
i know this isnt appearance cosmetic thread, but these are the wheels on the car, not my car.. ill think about it today, because its a 5 hour trip to his city and with ferries i cant just come and go as i please so.. i might go looking for something smaller
Old Jun 28, 2005 | 10:08 AM
Deemeetree's Avatar
Electrician
The best place to ask this question will be in Appearance and Cosmetic, which is found here:
https://honda-tech.com/zeroforum?id=28
Yes, you do have a technical question regarding your suspension setup, but there's PLENTY of users on Appearance and Cosmetic, who have ran 17" wheels, which will influence your decision even more.
IMO, don't go over 16", but that's my opinion. You come up with issues of rubbing and eating away your tires, sooner or later, with the rubbing that will occur on a daily basis.
Running 17" wheels on stock suspension will just look plain funny. I've seen PLENTY of Civics, on 17s, that look ridiculous on stock suspension with bigger rims. But then again, it's up to preference.
Old Jun 28, 2005 | 10:09 AM
jolt-tsp's Avatar
If you really like the look, don't let us talk you out of them. From a strictly performance perspective though, they'll just slow you down.
Old Jun 29, 2005 | 07:54 PM
daft's Avatar
I decided not to buy the 17's but get a set of brandnew 15's... any suggestions? I'm not loaded so I was thinking either Konig Heliums, or 5zigen FNO1R-C's... and what size tire should I get.. tirerack.com suggests 195/55-15...
Old Jun 30, 2005 | 05:06 AM
jolt-tsp's Avatar
Cheap racing wheels here, just don't hit a curb:
http://www.diamondracingwheels...s.htm
Also, I've always loved the lt. grey Kosei K1 TS's, but they're also not a strong wheel:
http://www.tirerack.com/servle...inted
