welding chassis
Old Sep 24, 2008 | 10:42 AM
TS4L's Avatar
Default welding chassis
I would like to do some small things to my car this winter but have a few questions. Can you safely weld with the engine installed? I will be cutting and welding inside the car but I worried that the current carried through the chassis from welding would damage the electronics? I plan to remove the hump under my drivers seat in order to lover the CG with lowering my seat. I also plan to install some gussets. I can pull the motor easily but thought since I am not welding near the engine bay if its not require I would leave it in. Who knows, I may just pull it out anyway and stitch weld the whole chassis. Thanks in advance, I'm new to welding and will have someone with more experience do the welding but just want to get it all figured out in advance.
Old Sep 24, 2008 | 02:06 PM
uselesshuman's Avatar
Default Re: welding chassis (TS4L)
ive never had a prob but if your worried instead of pulling the engine just unplug the ecu,battery,whatever you think but like i said ive never had a prob
Old Sep 24, 2008 | 11:25 PM
ClassicConcepts's Avatar
Put the ground clamp close to the weld and that will cut down on problems. Doesn't hurt to disconnect the sensitive stuff like computers.
Old Sep 28, 2008 | 09:52 AM
CleanLikeJdm's Avatar
Hype-R Stalker
I just disconnect the Neg terminal for the battery when welding, never had any problems.
Old Sep 28, 2008 | 12:09 PM
punkinbeck's Avatar
Default Re: welding chassis (CleanLikeJdm)
I think the only time you have to worry about computers is when you're welding with high frequency, but i wouldn't take any chances.. Ecus aren't cheap
Mad-Mike
Paint and Body
16
Feb 10, 2011 07:41 PM
redbrainz
29
Aug 10, 2010 07:25 AM
I AM WEASEL
Oct 8, 2008 06:40 PM
red95integ
Aug 4, 2004 11:38 AM
