welder reccomendations
Old Dec 5, 2007 | 03:36 PM
Area 51's Avatar
Default welder reccomendations
I'm a complete noob
Criteria
Price range- $250 preferably but 475 absolute max
Have no problem buying used if I have too but must be in good shape
uses- Exhaust, bracketry, light work
Must plug in household wall outlet
will probably use 1-3 times a month maximum
I would love something capable of light chassis and suspension work but know that my budget limits me a lot. I will never build a frame from scratch or cut up a frame so I don't need something that radical.
Any suggestions? Thanks
Old Dec 5, 2007 | 05:38 PM
manifoldmiketyson's Avatar
Default Re: welder reccomendations (Area 51)
i have a home depot lincoln mig. i think its a 90 amp unit. plugs into 110v. its about $500 though. i've had it for about 5 years, never had an issue. you may have to replace the gun after you run it over about 100 times.
Old Dec 8, 2007 | 04:52 PM
Area 51's Avatar
Default Re: welder reccomendations (manifoldmiketyson)
http://www.harborfreight.com/c...93793
What about this one?
Old Dec 8, 2007 | 05:52 PM
narfdanarf's Avatar
http://www.sears.com/shc/s/p_1...lders
I'd spend a little bit more and get one that might last for awhile. You can buy a kit to convert from flux-core to MIG later on, which will give you much nicer welds.
ep3rez
Jun 7, 2010 03:16 PM
howie
May 29, 2009 11:55 AM
Sketch_hs
Welding / Fabrication
Jun 15, 2007 09:58 AM
Xymox
Nov 22, 2003 03:59 AM
Black Dragon
Jul 27, 2001 07:56 AM
