update on the supra stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">
Im glad to see Im not the only one with a mess on my bench. I feel like its so unprofessional to have it looking that way but its so hard to keep it clean and organized.
BTW: Twins??
Braver man than I am, I wouldnt want to do that job. Looks fantastic though, great work.
BTW: Twins??
im doin it for a " buddy" but yeah. i regret doing this car. too much work not enough benefit/pay
my desk gets used by everyone in the shop and they dont clean up their messes. so it kinda just stays there. i make sure i clear a huge spot to work in
how did you weld up the space between the collector at its transition. not the flange . it would seem to be hard to get in there with a torch unless you pulled the tungsten out far but wouldnt that make the arc jump around?
clarify what you're saying ??
the collectors are welded before hand
collector to flange. tungsten is pulled out. gas turned up but i try to hit it at different angles where the torch can get it in there, pulse tig a little at a time to prevent the tungsten from hitting surrounding areas. then i try to go for a final bead.
i have already done this but it just a pain in the ***.
i was talking about the actual y collector the point when the 2 merge together. i would imagine going from side to top but for me to get the tungsen in between my arc seems to jump a bit. ill try and turn up the gas a bit and see if i can get a nicer bead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks »</TD></TR><TR><TD CLASS="quote">i have already done this but it just a pain in the ***.
i was talking about the actual y collector the point when the 2 merge together. i would imagine going from side to top but for me to get the tungsen in between my arc seems to jump a bit. ill try and turn up the gas a bit and see if i can get a nicer bead. </TD></TR></TABLE>
hit it with some high pulses and make sure your tungsten is well sharpened and clean
tightDA8
Dec 6, 2005 12:38 PM
Racerage1
Jan 26, 2005 04:12 PM
sexualy speaking
