tight radius bends?
Old Oct 20, 2008 | 03:18 PM
weiRtech's Avatar
OG Fabricator
Default tight radius bends?
why isn't anyone using tight radius pipe bends for their manifolds?
Old Oct 20, 2008 | 04:19 PM
Zornig's Avatar
Default Re: tight radius bends? (weiRtech)
probly because they are like 3x the price of standard bends and really no need for them unless your building somthing that requires them
Old Oct 20, 2008 | 04:27 PM
Agtronic's Avatar
That's pretty much my reason. My S4 manifolds require 1 tight radius, all the rest are long.
Old Oct 20, 2008 | 04:56 PM
rorik's Avatar
Or maybe because the tighter the bend, the shittier the flow.
Old Oct 20, 2008 | 10:52 PM
91jdmhatchback's Avatar
Default Re: (rorik)
i use the normal ones, sense they seam to work perfect for ramhorns, and logs and that kind of stuff.
Old Oct 21, 2008 | 03:45 AM
weiRtech's Avatar
OG Fabricator
so if you could get them cheaper, you'd probably be more inclined to use them? i don't understand why they are more expensive when they are a smaller part...
Old Oct 21, 2008 | 07:25 AM
DESTROYER's Avatar
probably a more difficult to manufacture part, or maybe something to do with quantity vs demand.
Either way, I have used them in ramhorns with odd placement exhaust ports.
Old Oct 21, 2008 | 08:44 AM
91TSiGuy's Avatar
Default Re: (DESTROYER)
I end up trying to use no more than one or two if I have to on manifolds here at work. As for cost, it definitely sucks, but price out transition 90* el's sometime.
Old Oct 22, 2008 | 06:07 AM
turboteener's Avatar
Banned
I have used them for downpipes. But they are a little bit more of a hassle to deal with. Plus they are more expensive.
Old Nov 10, 2008 | 12:25 PM
CRMB's Avatar
OG Fabricator
Default Re: (turboteener)
We have some new options for manifold builders. Our new induction bender just pulled off 1-1/4" sch 10 stainless bends on a 1D radius (1.660" OD x 1.660" radius). This radius is right between the current short radius (1.50") radius and the long radius (1.875").
I know for a lot of the manifolds we build, having legs on the bends would reduce the cost of building the manifold significantly. Also being able to source the proper bend angles on production manifolds will reduce the fabrication time. Combine that with a tighter radius easing fitment for tough manifolds .. This may drastically affect people's bottom line.
Just some food for thought.
Modified by CRMB at 3:44 PM 11/10/2008
Old Nov 10, 2008 | 02:25 PM
weiRtech's Avatar
OG Fabricator
pics of the bends? sounds hot.
Old Nov 10, 2008 | 03:14 PM
EdsGTI's Avatar
Default Re: (weiRtech)
i have seen tight radius ones from vibrant be like $14 Thats much cheaper than others.
Old Nov 10, 2008 | 03:15 PM
CRMB's Avatar
OG Fabricator
Default Re: (EdsGTI)
They have to be buffed as the process turns them blue.
And just to re-itterate, these are basically exactly half way between a long and a short radius fitting. They are 1*diameter in radius.
Old Nov 10, 2008 | 03:21 PM
weiRtech's Avatar
OG Fabricator
why does the process turn them blue? do you have to heat them up to bend them? looks smooth.
Old Nov 10, 2008 | 03:29 PM
CRMB's Avatar
OG Fabricator
Induction benders heat the material as its bent.
Old Nov 10, 2008 | 03:59 PM
project dc2's Avatar
Default Re: (CRMB)
PM me some prices
Old Nov 10, 2008 | 06:46 PM
DESTROYER's Avatar
holy crap you just made your mark on the world, way to go! These will be hot!
Prices? Custom bends?!?!?!?!?!? Gotta know!!!
Old Nov 10, 2008 | 08:00 PM
9295EJ-t's Avatar
i have used 1 on one of my manifolds... no need for them usually...
cmboostedek
Welding / Fabrication
Jan 12, 2012 04:02 PM
ToxicFabrication
17
May 18, 2011 01:51 PM
DRAGLS
Feb 28, 2005 06:18 PM
SSS2000
Jul 1, 2003 05:49 PM
BoostedH23a1
Mar 8, 2003 04:29 PM
