Throttle Body Question
Old Jul 17, 2005 | 09:38 PM
QIKXIT's Avatar
Default Throttle Body Question
I have recently helped a friend bore out his B18C throttle body to 64mm, but the one thing i can't get right is the butterfly plate, now my question is do they usually laser cut the plates or machine the plates down on the lathe, and i know there is some kind of a sealant you can buy for butterfly plates that have been worn due to wear that stops the vacuum leaks, much help would be appreciated.
Old Jul 18, 2005 | 12:58 PM
MY_EL_1's Avatar
Default Re: Throttle Body Question (QIKXIT)
The best way to get it to seal right is to cut it on a lathe.
You need to get a piece of bar stock, cut the end to the same angle as it sits in the body. Bolt the butterfly on to the bar a bit over sized. So when you cut the outter plate the edges are angled instead of 90deg to the face.
Old Jul 18, 2005 | 10:17 PM
QIKXIT's Avatar
Default Re: Throttle Body Question (MY_EL_1)
Thanks for the info, i will try that.
Old Jul 19, 2005 | 04:47 AM
MY_EL_1's Avatar
The butterfly will end up oval a bit.
juanchoenuncrx
Apr 8, 2008 07:10 PM
90b20vteckidd
Aug 17, 2006 12:02 PM
Simple
Sep 20, 2004 06:01 AM
