test pipe vs. resonator
Old Mar 17, 2006 | 07:34 PM
nasirjones9mm's Avatar
Default test pipe vs. resonator
okay I have a 00 Civic and I want to remove my catalytic converter for better airflow/more hp/louder. what would be the best mod for it. should i replace the catalytic converter with a test pipe or resonator.
Thank You Guys!!!
Old Mar 17, 2006 | 07:40 PM
SMSP's Avatar
Default Re: test pipe vs. resonator (nasirjones9mm)
Or a good hi flow cat
https://honda-tech.com/zerothread?id=1323923
Old Mar 18, 2006 | 07:12 AM
Default Re: test pipe vs. resonator (SMSP)
but out of the resonator/test pipe/hi flow cat which one would be louder, have more hp?
Old Mar 18, 2006 | 07:46 AM
david@didrace.com's Avatar
The obvious would be the test pipe, but it depends on how tight emissions testing is in your area.
Old Mar 18, 2006 | 01:32 PM
integrawhat's Avatar
Default Re: test pipe vs. resonator (backpurge)
this sounds like it might be a good question for my uncle ben he knows a lot about this kinda stuff you should try to find him and ask.
Old Mar 18, 2006 | 03:48 PM
BB6racer's Avatar
test pipe will give the most top end power. hondas aren't the kind of cars that sound good without a cat though. i've heard an ITR with a test pipe and it sounded horrible, way too raspy and bubbly. unless you can find an exhaust that was designed to run without a cat your car will sound really bad (and not too many companies out there make these for hondas if any at all!). i would say go with a high flow cat, and just run a test pipe when you go to the track. not to mention the CEL, emissions failure, the tuning you would have to do to optimize the test pipe, etc...
Old Mar 18, 2006 | 07:11 PM
Tony the Tiger's Avatar
I'd put a resonator in there, but a straight-through design resonator with no restrictions. Those should not hinder performance and offer a much cleaner sound.
Old Mar 18, 2006 | 08:08 PM
Mugencrxsir1's Avatar
Default Re: test pipe vs. resonator (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">I'd put a resonator in there, but a straight-through design resonator with no restrictions. Those should not hinder performance and offer a much cleaner sound.</TD></TR></TABLE>
y2kferari
Dec 11, 2009 05:22 AM
Sassafrass
Feb 6, 2006 11:32 AM
renegadez7o7
Sep 9, 2005 07:03 PM
all420
Dec 18, 2002 01:39 PM
blktyper2001
Oct 31, 2001 06:12 PM
