sand bending
Old Jan 5, 2007 | 01:18 PM
Toda Party's Avatar
Default sand bending
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RocCityRoller;1052516 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if this is the right spot for this, move it if need be. Stumbled across this on the forum I'm on in Michigan and thought it was an interesting/helpful read if you wanted to try something like this.
Old Jan 5, 2007 | 01:27 PM
RCautoworks's Avatar
Nice article and sexy shorts.
Old Jan 5, 2007 | 01:44 PM
eddie_ek's Avatar
Default Re: sand bending (Toda Party)
thats nice
Old Jan 5, 2007 | 02:07 PM
G2turbo_terror's Avatar
Default Re: sand bending (eddie_ek)
Interesting read but this is will haunt welding/fab forever
Old Jan 5, 2007 | 02:10 PM
Blind-Fashion's Avatar
Isn't that kind of how they make mandrel bends? fill them with sand and bend them? but without the heat?
Old Jan 5, 2007 | 02:23 PM
dave@passenger's Avatar
Oh no.
Old Jan 5, 2007 | 02:32 PM
F20Cteg's Avatar
Default Re: (Blind-Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind-Fashion &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that kind of how they make mandrel bends? fill them with sand and bend them? but without the heat? </TD></TR></TABLE>
HAHA, no
They insert a "mandrel" into the tube so that when the tube is bent it maintains it's structure.
Like here:
Old Jan 5, 2007 | 03:03 PM
Default Re: (F20Cteg)
Ahh, ok. Interesting enough.
Old Jan 5, 2007 | 04:17 PM
RedEj8's Avatar
Neat...DIY mandrel exhaust ftw
Old Jan 5, 2007 | 06:47 PM
RC000E's Avatar
Default Re: (RedEj8)
Definitely have heard of this technique, but that's a pretty good article. I have never seen actual pipe bent this way. It looks to be good quality. Might be worth trying.
crx12's Avatar
Wow, I can't imagine bending up 12" pipe that is 1/4" thick this way. Man I bet this guy has some cool stuff sitting around
Old Jan 5, 2007 | 07:21 PM
Tigfab's Avatar
Great article. I have some friends with vintage race cars that told me about the old school way to bend header tubing.
Old Jan 5, 2007 | 07:47 PM
Quickgti1.8t's Avatar
Default Re: (Tigfab)
very cool
Old Jan 5, 2007 | 10:33 PM
90dxhmt's Avatar
Default Re: (Quickgti1.8t)
Wow i think i have to try that just for the fun of it
Old Jan 6, 2007 | 01:31 AM
dutchaccord's Avatar
REMEMBER TO USE DRYED SAND!!!! otherwise the pipe WILL explode.
I have tried to bend some 2.5" exh piping this way, but it didnt really work out. It defenately isent as easy as it looks.
cua0's Avatar
i've done similar things with my hydraulic radius bender, never with heat and muscle though haha, i'm way too lazy for that ****.
Old Jan 6, 2007 | 10:12 AM
jewjew bean's Avatar
Default Re: (cua0)
article makes it seem way too easy. bet there's more to it otherwise no one would bother buying mandrel bends
Old Jan 6, 2007 | 10:51 AM
dmotoguy's Avatar
Default Re: (small arm)
i dont see too much "easy" in that article.. looks like it would take a pretty good amount of time and work to get a bend you can buy for not tooo much more than straight.
Old Jan 6, 2007 | 12:56 PM
93supercoupe's Avatar
Default Re: (dmotoguy)
thats nice is u need a really specific multiple bend pipe.But otherwise, its cont that cost/time effective.
Old Jan 6, 2007 | 06:27 PM
beepy's Avatar
Default Re: (93supercoupe)
Seems like a really good idea. Pack the sand in tight, weld on end caps, then bend that ish in your crappy die pipe bender. Should come out better than the die bender alone, right?
Old Jan 6, 2007 | 06:57 PM
Default Re: (beepy)
It should be said, this method is not safe for roll cages
Old Jan 7, 2007 | 06:08 PM
TGrant's Avatar
I know it has already been stated, but please USE OVEN DRYED SAND, otherwise you are working with a bomb.
Old Jan 7, 2007 | 06:16 PM
allricedout's Avatar
looks good, i wonder if i used the sand for a regular pump/ crush bender
Old Jan 7, 2007 | 06:42 PM
Howitt's Avatar
Default Re: (allricedout)
I tried this a few years ago I ended up with a garage full of sand and messed up tubing hes gets BMF award
Old Jan 7, 2007 | 07:26 PM
JT2MA71's Avatar
is it possible to just torch the moisture out of the sand, or does this need to be done in an oven?
I might try this out, it'd be nice to know how to do this. Just doing some 2" pipe for my wagon so I'm not running an open cat
