rust repair
Old Mar 25, 2006 | 04:54 PM
swappedcx's Avatar
Default rust repair
Ok, one thing thats got me confused. I have to do ALOT of rust repair on my 89 240sx. Its just a project that I want to mess around with. Now for example I need to cut out a peice of the floor and weld in a new sheet. Thats easy though becasue after its welded I can paint the bottom and top.
I also have some rust like in the door jam and the 1/4 panel area. After they are cut out, and now if I weld in new sheet metal, how do I protect the back of the metal? The inside I cant get to with paint, and if i paint it before i weld it in it will burn off anyway.
Any tips here?
Old Mar 25, 2006 | 05:24 PM
LordAphotic's Avatar
why cant you get to the inside section? you cant take off the inside panels or what?
Old Mar 25, 2006 | 07:01 PM
ManBearPig4silly's Avatar
3M weld through paint or whatever its called. You can google it. I've seen it at almost every auto parts store with a decent body repair/paint section.
Old Mar 26, 2006 | 05:11 AM
swappedcx's Avatar
Default Re: (LordAphotic)
no, mostly every part that needs to be welded has a support beam behind it, so you cant even see the rust from the inside.
Old Mar 26, 2006 | 09:03 PM
sc4dr's Avatar
Default Re: (swappedcx)
Use Aluminized Bioxide weld thru pimer. You apply it with a brush, before you weld in your new pieces.
Old Mar 28, 2006 | 01:29 PM
mike9571's Avatar
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">3M weld through paint or whatever its called. You can google it. I've seen it at almost every auto parts store with a decent body repair/paint section. </TD></TR></TABLE>
He said it, The weld doesn't come out as nice but it does the job!
SixxT9
Jun 21, 2009 12:04 PM
samflax
Jan 8, 2007 11:53 AM
k-man
Oct 25, 2004 03:47 PM
HamiltonRex
Jul 17, 2004 06:13 PM
Beave0101
Jan 20, 2004 06:28 PM
