Roll Cage Plates???
Old Jan 27, 2007 | 07:19 PM
BEEYOND's Avatar
Default Roll Cage Plates???
how are you guys welding in your roll cage plates. They don't sit flush with the oem panels of course. in the past i've added another smaller plate so it can be welded. sometimes hammering these small creases help to straighten them out... so just curious how some of you guys are doing it.
any close up pixs??? thx guys
Old Jan 27, 2007 | 11:08 PM
bigTom's Avatar
Default Re: Roll Cage Plates??? (BEEYOND)
I hammer them to contour with the oem surfaces. With flor plates persay; i'll tack weld sections that touch the floor when the plate is flat, then hammer and tack weld as I go along until the plate is flush with the floor.
Old Jan 28, 2007 | 06:55 AM
9bells's Avatar
OG Fabricator
Default Re: Roll Cage Plates??? (bigTom)
I usually hammer the oem panel, as it moves easier and is more pleasing to the eye.
Another option is to build a box for the tube to sit on. You just build a few vertical sides, with ends that fit into the contours, and a flat piece on top.
I have seen this done, and it looks nice, but in my opinion, it doesn't spread the load nearly as well.
Old Jan 28, 2007 | 04:41 PM
BEEYOND's Avatar
Default Re: Roll Cage Plates??? (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">I usually hammer the oem panel, as it moves easier and is more pleasing to the eye.
I have seen this done, and it looks nice, but in my opinion, it doesn't spread the load nearly as well.</TD></TR></TABLE>
yes was considering building a box like what you mentioned... i'm probably just going to hammer in the oem panels to fit like usual...
any close up pixs guys...
Old Jan 28, 2007 | 04:43 PM
BEEYOND's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigTom &raquo;</TD></TR><TR><TD CLASS="quote">I hammer them to contour with the oem surfaces. With flor plates persay; i'll tack weld sections that touch the floor when the plate is flat, then hammer and tack weld as I go along until the plate is flush with the floor. </TD></TR></TABLE>
thx, i'll take that into consideration... any pixs
Old Jan 28, 2007 | 08:09 PM
Race Egr's Avatar
do most of u guys prefer mig welding these or tiggin them?
Old Jan 29, 2007 | 03:12 AM
9bells's Avatar
OG Fabricator
Default Re: Roll Cage Plates??? (dr.NAPIER)
Mig welding is much faster, but most of the cages I put in are chromoly, so I TIG the plates in.
Old Jan 29, 2007 | 07:53 AM
hybridmoments's Avatar
the Box plates are actually a pretty good option.
especially if you make the box attach up along the inside rocker panels and too the floor also. it seems it is alot stronger then just welding a plate to the flat piece of floor pan, because the rockers are quite a few different peices of metal joined together and the floors are joined to those.
JDMdoode
Sep 7, 2019 02:48 PM
Todd00
Apr 3, 2011 07:37 PM
AlwayzSpoolin
Audio / Security / Video
Mar 7, 2010 08:57 PM
LumpyTheGrumpyCamshaft
Honda S2000
Aug 6, 2008 09:03 AM
STREETWERKZ
15
Nov 17, 2006 04:01 PM
