New setup: front mount S372
Jose, Danny and I decided to take Jose's car one step further. A new exhaust manifold, new turbo, new intercooler, new radiator, new downpipe, new wheels/tires for the street, new wheels/tires for the track, etc. This is just a preview of the new turbo setup :D I will update when there are updates
Thanks to Danny for all the fabrication as usual
the pipes werent beveled after the cut was made on them ? can you get full penetration and not overheat the material like that ?
also, the turbo sits kinda close to the engine, but there is mad room in the bumper where it could have been placed ?
one more thing... what whp is that IC rated for ?
Thanks!
Thanks! Will do
I will measure it again today
I will take pictures of the inside of the piping today
There is less room than there looks. We had to keep room for the downpipe, intercooler, radiator, overflow, air filter (yes we are running one, haha) and keep a good downward angle on the on the return line
I dont remember what the intercooler is rated for but the car will NOT be ran on gasoline most of the time. And never 93 octane
Thanks! Will do
On a side note we got the Hondsubishi up to 47lbs tonight
Yes I have a little videoNo. I will take pictures once complete. There is A LOT of distance from the headlight and bumper. Only thing we are some what worried about is the hood
I spy a couple cheater cuts too. It depends on what the pulse is set at. 200 amps could smoke the pipe or not be hot enough at all esp with only one pass. If you insist on not beveling it anymore I would suggest smoking a fusion root pass in there at 150 amps(move fast so you dont heat soak it) then just run a filler pass over it at about 90.
