Mounted Point?
You mean the aluminum is sticking in your bit? If so, you can use some PB Blaster, WD40, etc on your bit and on the aluminum to keep the aluminum from getting stuck in there. If you are going to weld, you will either have to clean it up really well afterwards or just keep doing it the way you have been. You ARE using a non-ferrous bit, right? It's the style with the serrations farther apart....
Dr Pooface
Welding / Fabrication
Mar 21, 2011 03:24 PM
