Making air ducts
Old Jan 19, 2005 | 10:49 PM
RCautoworks's Avatar
Default Making air ducts
Anyone have any pics or anything, need some ideas. I am looking into some sheet metal that I could bend very easily but the only concern is connecting the ends to get a perfect seal. Also any downside to using sheet metal rather then a plastic ? Would a galvinzed metal be ok, or would it get to hot and burn off. Just being on the safe side, want to double check. I don't think it will but want to hear what others have to say.
Anyone feel free to throw some ideas around since I searched and found nothing on this site about it.
Old Jan 20, 2005 | 12:00 AM
Kookz's Avatar
Resident Vagabond
Default Re: Making air ducts (90blackcrx)
What are you making ducts for that is going to get so hot, or require a perfect seal?
Old Jan 20, 2005 | 09:15 AM
Default Re: Making air ducts (Kookz)
Well it won't be that hot, its actually gonna take the place of the evaporator.
Old Jan 20, 2005 | 10:09 AM
Here is the piece.
After looking at the openings, I might just use some type of cardboard and foam to insulate it. It should not get to hot inside there should it ? I would think if it did it would be a fire hazard for Honda.
Old Jan 20, 2005 | 10:38 AM
rjardy's Avatar
Heater core?
Rob
Old Jan 20, 2005 | 11:33 AM
Default Re: Making air ducts (rjardy)
No, the evaporator.
Old Jan 20, 2005 | 11:48 AM
FORCED FED TEG's Avatar
New User
What I did was gutted the evaporator of every thing so all that was left is the black case. Then put it back.
Old Jan 20, 2005 | 12:09 PM
triple_s1x's Avatar
Default Re: Making air ducts (FORCED FED TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FORCED FED TEG &raquo;</TD></TR><TR><TD CLASS="quote">What I did was gutted the evaporator of every thing so all that was left is the black case. Then put it back.</TD></TR></TABLE>
Thats what i did also, getting something else to fit in that spot perfect is a pain in the ***.
Old Jan 20, 2005 | 12:33 PM
Default Re: Making air ducts (triple_s1x)
Not gonna happen because I don't have the piece anymore. And I don't feel like tracking one down and paying an arm and a leg for one.
Old Jan 20, 2005 | 12:40 PM
OverCenter's Avatar
What car is that for ?
Old Jan 21, 2005 | 09:24 AM
Syner-G-Racing LLC's Avatar
it looks like that hard plastic, abs? not sure but if its plastic it cant get too hot. plus metal would radiate any heat that it collected.
IMHO I would glass it and make a mold then make a fiberglass duplicate of one...oh ****...forgot you dont have the piece anymore huh? Junkyard?
Old Jan 21, 2005 | 09:34 AM
Default Re: Making air ducts (Syner-G-Racing)
I gotta a friend at the junkyard and he actually pulled one out of a crx for me, so I'll just be gutting it.
kommon_sense
Welding / Fabrication
Dec 16, 2009 08:10 AM
Lo-Buck EF
11
Oct 12, 2003 11:11 PM
JasonBlackEJ1
Mar 17, 2003 12:25 AM
Redsun
Dec 1, 2001 03:25 PM
