JB Weld
Old Aug 31, 2004 | 12:22 AM
  #26
aut0tek's Avatar
Default Re: Re: (turbohondask)
I don't think anything can touch this...
I had pits in the deck of my LS block due to an idiot installing my blockguard with a hammer.
I would've had it resurfaced but at the time I was told the head I had was milled .035 which would've made my compression around SKY HIGH. lol.
There were only 2 pits I was worried about because they were obviously going to cause cyl 2 + 3 to leak...
Anyhow, I sanded it down with some 800 grit, put some JB Weld in there and razorbladed it smooth.
Then just lightly touched it up with some more 800 grit after it had fully hardened.
Held up for 3000 miles. Then it finally gave out. LOL. And that's why I'm doing a rebuild... but hey... 3000 miles for like what? $10.00 ??? Can't beat it.
LMAO
Ratliff
Old Aug 31, 2004 | 05:19 AM
  #27
h22a193's Avatar
is jb weld ok to use on a oil return line for a steel oil pan, on a turbo car?
Old Aug 31, 2004 | 06:21 AM
  #28
Dan GSR's Avatar
Default Re: (h22a193)
jb quick has a much lower temperature rating
i'd try regular jb weld first
Old Aug 31, 2004 | 08:52 AM
  #29
@irborne's Avatar
Default Re: JB Weld (sleep)
uggh. you gotta give JBWeld more props. these stuff cure saved my *** many times, including my expensive radiator that was ripped open by a rock on the freeway, it's been 3 years past and the weld held together fine.
Old Aug 31, 2004 | 09:48 AM
  #30
577HondaPrelude's Avatar
Default Re: JB Weld (@irborne)
Mad props y0 to:
Duct tap
Zip Ties
JB Weld
Old Sep 1, 2004 | 10:35 AM
  #31
DsMWookie's Avatar
Default Re: JB Weld (577HondaPrelude)
Can't Duct it **** it
I live
Zippies
JB weld
Duc Tape
and the al mighty Cheater Bar
Old Sep 1, 2004 | 11:16 AM
  #32
SJcivic's Avatar
Default Re: JB Weld (DsMWookie)
Yes, I beleive Zip-ties to be one of the best inventions ever.
Rich
Old Sep 2, 2004 | 10:26 PM
  #33
darrinbrewer's Avatar
Default Re: JB Weld (SJcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJcivic &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I beleive Zip-ties to be one of the best inventions ever.
Rich</TD></TR></TABLE>
i know a lot of people that need "sponsored by zip-tie" on there car..lol
Old Sep 2, 2004 | 10:45 PM
  #34
RCautoworks's Avatar
Default Re: JB Weld (darrinbrewer)
If I ever have to use jb weld I always try to use a piece of metal or something else that is strong underneet. I used a dime plus jb weld to cover up injector holes in manifolds before, works great.
Old Sep 3, 2004 | 12:01 AM
  #35
AMH22A's Avatar
Default Re: JB Weld (90blackcrx)
JB weld works well. even quick steel also. i use it on my radiator.
damn rocks.
Old Sep 3, 2004 | 07:43 AM
  #36
HT Chaplain's Avatar
Loved
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">JB weld rocks, it has so many uses.. it fixes radiators!</TD></TR></TABLE>
Old Sep 5, 2004 | 09:13 PM
  #37
Nature's Renewal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">Mad props y0 to:
Duct tap
Zip Ties
JB Weld</TD></TR></TABLE>
Quote of the day
Old Sep 6, 2004 | 09:59 PM
  #38
hammerdgolfer's Avatar
jb weld is a godsend, my integra was wrecked when i bought it, it had the hood pushed up intoo the top of the head and the valve cover with a few cracks in both, jb weld fixed that **** right up in 10 minutes and for 4.49 instead of 60 bucks for a headgasket and like 5 hours of hard work to replace the head,
i also shaved my key hole on the trunk becaus someone tried to break into the trunk ******* it up, but i just did that tonight so i will know how it turnd out tomorrow
jb weld is awesome for dumbshit
Old Sep 7, 2004 | 02:39 AM
  #39
quik sol's Avatar
JB Weld is the best, I actually keep it in my glove compartment. I never heard of it until I started turboing my honda, and went to the return on the pan...friend said "jb weld it"...I was like wtf?...grabbed the stuff and already went through 4 packs of the stuff. its fun
Old Sep 7, 2004 | 03:33 PM
  #40
nonsense's Avatar
Default Re: JB Weld (SicNA94TegGsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicNA94TegGsR &raquo;</TD></TR><TR><TD CLASS="quote">There is stuff we used to use at my last shop called something like "marine tech" its avail at boat stores, and they should know what you are talking about. When I asked the master tech there about my friends Dodge intake runner that was cracked, he said that this stuff was stronger. Just a thought</TD></TR></TABLE>
yes that stuff rocks too. The best part about it is that it can be used under water and it still cures completely. I've patched a hole in the bottom of a jet ski with it before. Never leaked again.
JB Weld is also pretty good for misc repair
Old Sep 8, 2004 | 09:37 AM
  #41
daidilus's Avatar
HOLY EFF man....a socket fell inbetween my axle and my tranny case, when it rolled i popped a hole in the tranny about the size of a quarter..no one wanted to fix it...so JB welded it.....500 miles later....still good
Old Sep 9, 2004 | 12:22 PM
  #42
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote"> I used a dime plus jb weld to cover up injector holes in manifolds before, works great.</TD></TR></TABLE>
HaHa! Dimes? LOL! Ingenious!
Old Sep 9, 2004 | 05:45 PM
  #43
green91's Avatar
I JB welded my oil return fitting in my oil pan.. i cleaned it all up very well.. and i also threaded the fitting in. I jb weld around the edges and no signs of leakage yet!
Old Sep 9, 2004 | 06:42 PM
  #44
Default Re: (green91)
i also used it more in the past few days shaving my spoiler holes(i will redrill them whe i get a itr spoiler) shaving the side molding holes on my integra(type r yo) and last but not least i put a ton of jb weld all over the ignition......i kinda feel bad becaus the first person who tries to steel my car is gonna be like "???WTF??????WTF?????OHH **** WHATS THIS?????" and the moral of the story is dont mess with jb weld yo
Old Sep 9, 2004 | 06:56 PM
  #45
adictionbass's Avatar
Default Re: (hammerdgolfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammerdgolfer &raquo;</TD></TR><TR><TD CLASS="quote">i also used it more in the past few days shaving my spoiler holes(i will redrill them whe i get a itr spoiler) shaving the side molding holes on my integra(type r yo) and last but not least i put a ton of jb weld all over the ignition......i kinda feel bad becaus the first person who tries to steel my car is gonna be like "???WTF??????WTF?????OHH **** WHATS THIS?????" and the moral of the story is dont mess with jb weld yo
what did you do? coat the whole thing?
Old Sep 9, 2004 | 07:32 PM
  #46
Colin's Avatar
Default Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">
what did you do? coat the whole thing?</TD></TR></TABLE>
JB weld actually works really well for shaving holes. Obviously not as good as welding them shut, but way bettery than bondo. And of course you're not gonna want to span large holes... but emblem holes, no prob
Old Sep 10, 2004 | 07:25 PM
  #47
XDEep's Avatar
Default Re: (91IntegGS)
they need to sell jb weld in bigger tubes
Old Sep 10, 2004 | 07:38 PM
  #48
TRG-Coating's Avatar
Resident powder coater
Another good product is something called lab metal. I use it to fill holes and use it like bondo for powder coating since it is conductive...best part is you can buy it in like 12 oz cans and its a one part system.
Old Sep 10, 2004 | 07:41 PM
  #49
just the back,
Old Sep 11, 2004 | 08:19 PM
  #50
patientzero's Avatar
The head on my oil pan drain plug is stripped like a bastard and I was thinking about JB welding a socket or something to it to get it off. Does anyone think that's going to work?
btw- 100% agree that zip ties are the ****.
