I need custom speedometer options
Old Feb 14, 2007 | 09:26 AM
eightvalver's Avatar
Default I need custom speedometer options
The car I have has NO provisions for a gear driven vehicle speed sensor...so i need something custom to attach to a wheel or something for a signal but i dont even know if such a product is out there...need suggestions...thanks...
Old Feb 16, 2007 | 07:08 AM
dfoxengr's Avatar
Default Re: I need custom speedometer options (eightvalver)
gps or induction sensor or hall effect...
tons of options
Old Feb 16, 2007 | 07:57 AM
Str8 outta Cliff's Avatar
Default Re: I need custom speedometer options (dfoxengr)
does anyone know what would be needed to use one of the abs wheel speed sensors to provide a vss signal to an obd1 ecu?
Old Feb 16, 2007 | 08:08 AM
nfn15037's Avatar
Default Re: I need custom speedometer options (Str8 outta Cliff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Str8 outta Cliff &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know what would be needed to use one of the abs wheel speed sensors to provide a vss signal to an obd1 ecu?</TD></TR></TABLE>
The wheel speed sensors are VR sensors while the VSS is a hall sensor I believe. You need a way to convert a sinusoidal wave into a square wave. Autronic makes a box to do this for crank angle sensors but you need to get the number of pulses/mile correct. You'll probably have to grind some teeth off of the reluctor ring but it shouldn't be a huge project to do.
Old Feb 17, 2007 | 07:16 PM
xci_ed6's Avatar
Default Re: I need custom speedometer options (nfn15037)
service manual lists that for the VSS.
ColeCooper90
Jan 4, 2019 12:35 PM
woszczy
Jun 3, 2012 08:05 PM
dropped93ex
Dec 24, 2011 03:44 PM
hbcrazy88
Sep 20, 2010 12:36 PM
The_Sober
May 2, 2006 10:21 AM
