hows this weld?
. It depends on what obstacles are in the way if its an easy weld less, because the more gas coverage the better, but also when you drop the rod in its always dropped alot more in for me then it would be for dipping it so it needs alot less time to cool and it ends up staying a fairly consistent color. Usually my electrode is 1/8th if that away from the weld and theres barely enough room to fit the rod in there.
yeah I didnt read my post before posting. sorry for it not making any sense. No penetration on the weld you can see so I figured that none of the welds had penetration. Just watch the puddle next time you weld and you will see what I am talking about.
so would these weld not hold up on anything?
Those welds would be fine for boost piping, and you can make even smaller beads without any problems. When I need to do boost pipes, I fusion weld them and make it as tiny as possible, the customers love it, and it holds up fine. Not everything needs to be welded like it's going on a military submarine, sometimes it's OKAY to make a weld with esthetics being #1 priority.
I use the same technique as FredC and the nickname for it is "ball dropping" something I learned later on in the years while welding professionally. It makes the appearance on stainless look great and helps control the amount of heat by balling up your wire and letting it drop into your weld pool and cools down faster than dabbing it. Also feeding more wire like Agtronic does the same as technique above and both can do it all in one pass. I think the key here is consistency and feeling comfortable welding around a contour like that.
Oh yea, another thing I love and I do not know why other people think is a crutch is using the pulsing option. Look into that
It just seems like your care more so about how to learn the dime effect, rather then learning the basics first. The dime effect willl come down the line, once you understand things a little bit more. I'd just say keep practicing the basics.
Originally Posted by ToxicFabrication
i can weld a t joint with perfect dimes and penetration all the way.
it all goes hand and hand. If your in here asking for torch angle you can't weld a perfect t joint.
sense torch angle like mentioned earlier is dependent on what weld your doing at the time. but as a general rule you keep the torch angle the same from flate plate to pipe, you just are constantly adjusting it on pipe.
this is stuff you pick up from practice. and most of your questions could be answered by going on millers website or searching google.
also just from looking at your welds in your threads, you need to adjust your additude towards your welds just as must as your technique. this keeps you from getting all lazy and thinking your the **** because you can weld...
anyway,
sch 10 SS 304 pipe
welder set at 80 amps ( i use about 80-90% of that depending)
1/16" 308 rod
3/32" red tung.
i do 2 passes, 1 root with no filler, and 1 cap pass with filler.
if your going to run a root without filler, run it hot or it does you no good to do it.
That's how many welders think when they come out welding school. But not everything is high pressure piping. You have to learn to balance esthetics with weld strength when you're doing cars for people who like to show them. In a racing application, of course you will always try to make the strongest weld possible, but not always so for hot rods and show cars.
Just my $0.02 ...
Just my $0.02 ...
This is a bit confusing to me. I don't understand how you "think" you can welds AL and a T joint perfect, yet can't put a bead on a pipe?
anyway,
sch 10 SS 304 pipe
1/16" 308 rod
3/32" red tung.
anyway,
sch 10 SS 304 pipe
1/16" 308 rod
3/32" red tung.
Just my $0.02 ...
Just my $0.02 ...
he's saying it's fine for IC piping, but I wouldn't set my goal as creating a weld that doesn't penetrate the inside of the pipe.
but at the same time, on larger diameter and longer piping, it's going to take a lot of gas to purge the inside, and that can get expensive.
thanks guys
Well if you think about, if you have 50% penetration, and vibration moving through a pipe, that joint with 50% penetration is half way cracked already. Thats about as simple as i can put it. Now if you throw heat, from a primary into the mix, well you can do the math
the weld wouldnt pass an xray and wouldnt fill the entire gap using that method. You dip to fill the puddle into the gap.
Atleast that is what we learned at hobart.
We're not welding aircraft/food industry parts here. Also I doubt we want to get technical on what specifications we're supposed to weld race car parts off. All we're looking for is to make sure is the welder has a good understanding of how to pull off a good weld with more of a visual quality then what we look for industry wise.
Blah!
I hate to be cocky, but thats my average day at welding, I rarely remember to take pics because I'm either busy working or busy getting the f out to go home. I've looked at alot of the welds on here and the only person i'd say could weld stainless better then myself is Engloid. I'm sure there are some people on here that can weld great, but im judging from the pics i've seen
iBrandon
Welding / Fabrication
Feb 29, 2008 06:39 PM
*Boostwerks*
82
Apr 14, 2007 03:10 PM
