Fuel pump mount
Thought this might be the best place to show off my new design. Pretty much just completed machining this the other day. It is a mounting bracket for my waterman mechanical fuel pump. I know I remember seeing someone else on here was doing one for a honda, so I thought I would share my creation.
I have some new pictures, just havn't uploaded them yet, had to reformat my computar.
Let me know what you guys think!
yessir! I was going to use the Lovejoy couplings, but they really wouldn't work out for the way I planned on implementing it. So I just used their elastomeric spider, and designed around it. Made all the parts on my mill.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlbertRaczynski »</TD></TR><TR><TD CLASS="quote">yessir! I was going to use the Lovejoy couplings, but they really wouldn't work out for the way I planned on implementing it. So I just used their elastomeric spider, and designed around it. Made all the parts on my mill.</TD></TR></TABLE>
I see.
your machine work looks really nice. I'm not sure I would have been able to resist doing a full polish on the cross piece though...its begging for it.
I see.
Coupling is aluminum, and weighs next to nothing. That one looks a bit rough from handling it alot (its got my grimey finger prints all over it). I was going to offer in machined finish (which is damned near mirror, just small polishing would clean it up nice) or in anodized black, with my logo cut in after its anodized.
That pump flows 6.8 gallons per minute. Great for feeding 10 1600cc/min injectors with methanol. Will also have no problems running an 80 psi base. It also draws 0 amps from my battery. So now I can ditch the alternator, and have the biggest power drain, be the ECU/dash.
but instead of current draw, u now have extra rotating resistance.
I guess the main advantage would be the really high flow pump.
What does that pump cost?
What would the whole setup cost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">but instead of current draw, u now have extra rotating resistance.
don't forget the alternator was rotating resistance...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlbertRaczynski »</TD></TR><TR><TD CLASS="quote">So now I can ditch the alternator, and have the biggest power drain, be the ECU/dash.</TD></TR></TABLE>
not running an ignition system?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly »</TD></TR><TR><TD CLASS="quote">
not running an ignition system?</TD></TR></TABLE>
Minor details
You got my jist. Yeah a loaded up alternator will create plenty of drag on the motor too.
Yeah Stephanie's car has a similar setup, although my drive mechanism is a bit different. This is the same pump John Shepherd is running 7.70's with, and as far as I know he is feeding 10x 1600cc/min injectors.
Thanks for the comments guys! I appreciate it, I have put alot of hard work into designing and machining this so far.
Minor details
You got my jist. Yeah a loaded up alternator will create plenty of drag on the motor too.Yeah Stephanie's car has a similar setup, although my drive mechanism is a bit different. This is the same pump John Shepherd is running 7.70's with, and as far as I know he is feeding 10x 1600cc/min injectors.
Minor details
Thanks for the comments guys! I appreciate it, I have put alot of hard work into designing and machining this so far.</TD></TR></TABLE>
hey, you never know, maybe ur tryin something new? nice work
Minor details
