Fixing Type R Wing...
Old Oct 19, 2006 | 12:57 PM
standbackimapro's Avatar
Default Fixing Type R Wing...
Ok, my friend has a type r wing, and it was cracked straight in half in the middle, we tried some epoxy **** to try and fix it but it didnt work
So i got some Fiberglass cloth and resin, im just gonna put some of the resin around the crack, then wrap a strip of the sheet around the crack, and put some more resin around that
Old Oct 19, 2006 | 02:30 PM
MajorPayne's Avatar
Default Re: Fixing Type R Wing... (standbackimapro)
what are they made out of? abs or polyurethane?
Old Oct 19, 2006 | 05:27 PM
InfamousRS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">My friend put on a type r wing onto an LS, He had to cut it so it would fit ( he cut a little bit out of the center)
How should i combine the halfs back together?
Im thinking about just getting fiberglass resin and sheets and do it...
How exactly would i do it?
I was just gonna put some resin on it, then wrap a sheet around it, then resin the sheeet then sand it off and paint it </TD></TR></TABLE>
The real story, as found here: https://honda-tech.com/zerothread?id=1785754
Old Oct 19, 2006 | 05:48 PM
LostAndFound's Avatar
you blew up his spot.
a type R on an LS...why did he even have to cut ..or "crack" it . should have fit no problemo.
in that case, the inside is usually foam. who knos stick some 1 ft metal rods in there for structural support so half a foot goes in each end. then put some resin on the inside of hte wing, then push the wing closed, then fiberglass the outside, sand, and bondo, and prime thats how i would do it.
92egSnatch
Honda Civic (2001 - 2005)
13
Apr 29, 2007 02:31 PM
standbackimapro
Oct 19, 2006 04:12 AM
kartman
Sep 19, 2006 12:23 PM
weakGOODJunKieS.com
Jun 16, 2003 09:00 AM
