ef front end question
Old Nov 4, 2008 | 07:29 PM
shonbz's Avatar
Default ef front end question
i got a question, i have my drag car that i bought with the one piece front end on it along time ago, does anyone know if i can buy the piece thats been cut off and have it rewelded on so i could make it back into a street car? here is a pic
Old Nov 4, 2008 | 07:59 PM
cua0's Avatar
sounds like an awful lot of work, why not just buy another ef? probably end up costing you about the same
Old Nov 4, 2008 | 09:43 PM
LA_HONDAS's Avatar
Default Re: (cua0)
you can them from honda
Old Nov 4, 2008 | 10:23 PM
shonbz's Avatar
Default Re: (cua0)
Its not that much work, its one piece<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like an awful lot of work, why not just buy another ef? probably end up costing you about the same </TD></TR></TABLE>
Old Nov 4, 2008 | 11:09 PM
HiProfile's Avatar
Default Re: (shonbz)
The EF core support is like sheetmetal compaired to 92+. The front x-member is used to create most of the support, and the front x-member is basicly spot-welded on. Go to a junkyard with a sawzall & 2-3 batteries, ask nicely, and trailer your new front clip away.
Old Nov 5, 2008 | 08:54 AM
shonbz's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">The EF core support is like sheetmetal compaired to 92+. The front x-member is used to create most of the support, and the front x-member is basicly spot-welded on. Go to a junkyard with a sawzall & 2-3 batteries, ask nicely, and trailer your new front clip away.</TD></TR></TABLE>
yah thats what i figured, i want to put a normal front end on it cause i wanna turn it into a lil road race machine, so what i need is called the front x member?
Old Nov 5, 2008 | 05:51 PM
LA_HONDAS's Avatar
no its called a core support
Old Nov 5, 2008 | 06:57 PM
shonbz's Avatar
Default Re: (LA_HONDAS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS &raquo;</TD></TR><TR><TD CLASS="quote">no its called a core support</TD></TR></TABLE>
oh nice, thanks alot bro
Old Nov 5, 2008 | 10:00 PM
Garage 808 Hatch's Avatar
looking at that pic, you need quite a bit more than just the core support. it appears part of the aprons have also been cut off. its doable, but a bit of work
Old Nov 6, 2008 | 02:51 AM
wolve's Avatar
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shonbz &raquo;</TD></TR><TR><TD CLASS="quote">
srry for going a lill offtopic
but is that a jazz 1 gallon fuell cell, and is the way it's mounted according to the rules...?
i'm asking because i intend to use a jazz 1 gallon fuell cell in the location of the window washer fluid and am interested in mounting options/rules
thnx in advance
Old Nov 6, 2008 | 11:56 AM
shonbz's Avatar
Default Re: (wolve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wolve &raquo;</TD></TR><TR><TD CLASS="quote">
thnx in advance</TD></TR></TABLE>
ahah no prob man, yes it is mounted according to rules, has passed many times
Old Nov 6, 2008 | 04:03 PM
it technically is ILLEGAL. its supposed to have a steel bar around it to protect it from impact, as the fiberglass will protect it very little. although, i had mine just like that but on the drivers side for a few years and never failed tech. Now that i have learned it needs a bar, i have added one
Old Nov 8, 2008 | 10:39 AM
shonbz's Avatar
pics?
Old Nov 8, 2008 | 08:14 PM
the rules state it must be within the confines of the METAL body. so our interpretation is that just behind the fiberglass is not correct. after speaking to a few ppl on here, i was told that it should be encased in metal surround, like a cage bar. so i used some extra cage material and fabricated a bar around it
Old Nov 10, 2008 | 07:48 AM
SOHFAST94's Avatar
Default Re: ef front end question (shonbz)
This ought to help...
http://www.hondaautomotiveparts.com
Old Nov 10, 2008 | 01:42 PM
shonbz's Avatar
Default Re: ef front end question (SOHFAST94)
Originally Posted by SOHFAST94
thanks man! great avatar btw lol
tinyracer
10
May 4, 2008 02:19 PM
Honda_ThuGZ
Sep 23, 2007 04:55 PM
ekans
Dec 29, 2006 09:15 PM
C_I_V_I_C
Sep 4, 2003 10:21 PM
