DIY Welding Learning? Easiest machine to start with...
Old Aug 12, 2004 | 06:01 AM
Full Race A6's Avatar
Default DIY Welding Learning? Easiest machine to start with...
Looking to get into welding, not hard core welding and I dont care about prettyness, I just want to be able to tack **** in place or weld up my exhaust and little things like this. Maybe a little body work
How do I learn? Whats a great machine to start on with no absouletely none zip nada teacher or anyone even close to qualfied to show me a thing?
Thanks
Old Aug 12, 2004 | 06:03 AM
B18C1CYA's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (Full Race A6)
mig is the easyest to use hands down,
Old Aug 12, 2004 | 06:13 AM
spiceisler's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">mig is the easyest to use hands down, </TD></TR></TABLE>
I agree!! Point & Shoot.
Old Aug 12, 2004 | 07:23 AM
Bailhatch's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (clean90Si)
mig is easy but oxy/acet will give you some skills and is a more versatile setup. cut, weld, braze, saute can't beat it.
Old Aug 12, 2004 | 07:33 AM
Dr. EKology's Avatar
MIG Oxy would work too, but MIG would allow you to do more realistic, household jobs.
Old Aug 12, 2004 | 09:39 AM
Default Re: DIY Welding Learning? Easiest machine to start with... (EKology)
Is there special feautures on a welder I should be looking for?
Is the wire really expensive? Different sizes for different jobs?
Basic cost for a noob for a unit?
Good brand names
Thanks so far
Old Aug 15, 2004 | 05:17 PM
91civicEX's Avatar
id like to know too, bump
Old Aug 15, 2004 | 05:34 PM
MIDNIGHT's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (91civicLX)
iw ould say get a basic wire welder from home depot and start there. cheaper then a mig set up and good for what you want.
Old Aug 15, 2004 | 07:07 PM
silly sohc's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (MIDNIGHT)
MIG is cheap.... definately easy to use... 2lb wire spool here in CDN is $11. I"ve got a small lincolin MIG and a 275 model TIG. Both work great. The mig uses arg/o2 mix and the tig uses straight ARG. Hard to say how long each tank/spool will last for everyone, I do a ton of welding. but yeah, a good first welder is a lincoln 135 series
Old Aug 16, 2004 | 12:50 AM
b18cpowered's Avatar
i need to get me one of thoes
Old Aug 16, 2004 | 07:28 AM
raider099's Avatar
i got the $320 lincoln weldpak100hd from home depot. its been helpful so far, im about to but the gas conversion kit for it.
Old Feb 3, 2005 | 01:09 PM
contender's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (silly sohc)
where can i get one of these migs
Old Feb 3, 2005 | 05:50 PM
GS8HFL21's Avatar
Default Re: DIY Welding Learning? Easiest machine to start with... (contender)
HOME DEPOT SWALES!!!! j/k look at post above this
silentdaredevil2
Welding / Fabrication
52
Jul 3, 2006 10:11 PM
JRizEJ6
Dec 2, 2005 05:40 PM
*Boostwerks*
18
Nov 23, 2005 02:11 PM
Deathwish
Jun 1, 2005 01:22 PM
B16CRXT
May 15, 2005 08:09 PM
