cleaning between passes.
Old Apr 6, 2005 | 06:33 PM
LostCRX's Avatar
Default cleaning between passes.
How do you pro do it? It seemed like no matter how hard i tried, i still get really bad contamination after the first pass. I used a wirewheel on a grinder, i even tried dremel tool with a lil ss brush, and wipe with acetone afterward. Thanks for all the tips.
Old Apr 6, 2005 | 06:55 PM
Want2race's Avatar
Default Re: cleaning between passes. (LostCRX)
are you wiping the acetone off?
Have you tried another can of acetone incase yours is contaminated?
Old Apr 6, 2005 | 07:15 PM
Engloid's Avatar
OG Fabricator
Default Re: cleaning between passes. (Want2race)
If you can't hand brush it while it's still warm, and get the color off of it, you're doing something wrong.
Old Apr 6, 2005 | 08:09 PM
LostCRX's Avatar
Default Re: cleaning between passes. (Engloid)
what do you mean by hand brush it engloid? are you telling me not to use the bench grinder?
Old Apr 6, 2005 | 09:49 PM
Goullish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by hand brush it engloid? are you telling me not to use the bench grinder?</TD></TR></TABLE>
With a wire hand brush.
Old Apr 7, 2005 | 05:25 AM
david@didrace.com's Avatar
Mig, tig or stick? Anything with flux and spatter will take a little bit of effort to clean up. E6010 is a bitch to clean up compared to E7018, but it can still be cleaned up with a brush. If you're running too hot, it'll be a lot harder to clean off the flux.
Old Apr 7, 2005 | 09:36 AM
CRXDrew's Avatar
I love my handheld wire brush.
Old Apr 7, 2005 | 12:58 PM
LostCRX's Avatar
thanks everybody for the help, it's tig by the way.
Old Apr 7, 2005 | 02:53 PM
Default Re: (LostCRX)
Tig'ing most metals should need little to no cleaning between passes. With tig you're adding 0 (zero) contaminants if you clean properly before hand.
Old Apr 7, 2005 | 08:07 PM
Engloid's Avatar
OG Fabricator
Default Re: (backpurge)
Yes, hand brush is what I meant....as pictured above.
I usually dont reccomend any sort of electric or air powered brushing. If you can't brush it off by hand, there's something else wrong. However, the exception is if you're trying to brush color off after the pipe has cooled. You'll about have to use some power brushing.
The reason I don't reccomend using any powered brushing is because very small particles of the brush will become embedded into the metal you're welding. This can create problems....especially if you're welding aluminum. Aluminum doesn't weld well when you have bits of stainless embedded in it
Fabritory
Welding / Fabrication
26
Sep 8, 2006 07:22 AM
saywhat
Jun 12, 2006 04:11 PM
@irborne
17
Nov 6, 2005 04:32 PM
jDMJeRk
Jul 28, 2004 09:33 PM
GreenBean
Apr 13, 2003 01:43 PM
