Catch can Baffling
Old Dec 3, 2008 | 04:36 PM
TurboFocus's Avatar
Icon2 Catch can Baffling
Hey guys i tried searching this but nothing came up. so how are you guys baffling your catch cans. im mostly talking about the custom fabricated kind. im getting ready to make one and just wanted to see how you guys do it. also include pics of your catch cans setups if you want
Thanks
Jim
Old Dec 3, 2008 | 06:53 PM
JDM KID 510's Avatar
https://honda-tech.com/forums/showthread.php?t=1778967
Old Dec 4, 2008 | 10:08 AM
TurboFocus's Avatar
Thanks but not really what im looking for it just tells about steelwool which im not wanting to use anyone else
Old Dec 4, 2008 | 12:05 PM
downest's Avatar
Old Dec 4, 2008 | 04:28 PM
TurboFocus's Avatar
Thanks you Downest thats what i was looking for
Old Dec 4, 2008 | 04:30 PM
mauroalvarez@yahoo.com's Avatar
just wondering- whats the REAL point of having a catch can?
Old Dec 4, 2008 | 04:52 PM
Andrew Marquis's Avatar
omg.
Old Dec 4, 2008 | 05:22 PM
downest's Avatar
It looks cool.
Old Dec 4, 2008 | 08:10 PM
srmofo's Avatar
damn downest, you aint F@#king around with your baffling, how are you going to drain the oil out though?.....the real point of a catch can???? to catch stuff.....in the can!
Old Dec 4, 2008 | 09:43 PM
downest's Avatar
Pick it up and flip it over, you can see there is space to flow under and around the plates, I put a little brake clean in there and swish it around, then blow it out with the compressor.
Old Dec 5, 2008 | 08:01 AM
srmofo's Avatar
why not just weld a petcock onto it?....either way thats a pretty badass can
Old Dec 5, 2008 | 10:22 AM
downest's Avatar
I gave that one away to a friend, I'll be making a new one for my car before spring time, I have a couple of new designs in mind. I will either use a petcock or drain via the exhaust and a slash-cut bung.
Old Jan 8, 2009 | 08:30 PM
Tyson's Avatar
Default Re: Catch can Baffling
huh, so thats whats inside...
Old Jan 8, 2009 | 09:03 PM
redboost10's Avatar
i baffled it like you do when you install a sump to the tank.
Old Jan 9, 2009 | 08:32 AM
6000pounds's Avatar
First off let me say nice work on the replies pics. Secondly I'm a noob. I ordered a greddy catch 12mm catch can and just got it yesterday and haven't put it in yet. Correct me if I'm wrong but a catch can is designed to catch the access pressure and relieves the pressure from your head yes? Instead of your pistons burning up the oil?
Old Jan 9, 2009 | 08:47 AM
h2.4's Avatar
downest, on the fourth pic of your baffling, doesn't that last baffle before your filter have to be vented at the top like the first baffle? once your oil level reaches the bottom of that second baffle, it'll seal your "vent" won't it?
Old Jan 9, 2009 | 08:58 AM
downest's Avatar
Kind of. There is a little space around the sides of the plates, so even the hole in the first plate isn't necessary. I wasn't sure what was going to work so I guessed, it worked great for me while I had it in my car.
Old Jan 9, 2009 | 09:16 AM
h2.4's Avatar
oh, yeah, i didn't see that at first. so the baffles are narrower than the can. so it can vent around the baffles. cool.
Old Jan 9, 2009 | 09:56 AM
patriot's Avatar
Catch can is to catch oil that gets blown there from piston blow-by. The tube on the head acts as an inlet to allow air to flow into the block as the pressure in the block pushes the oil out the vent tubes and therefore into your catchcan...although, a well designed system will allow it to drainback into the block. See theoldone.com...
Old Jan 9, 2009 | 10:26 AM
downest's Avatar
Draining back to the block has nothing to do with good design, it's an option in the design. Some people like it to drain back like factory, personally I don't. The next catch can I make for my car and the one I make for our other car here will drain via a valve and a slash cut bung in the exhaust.
There are TONS of threads and debates about catch cans on here, they are linked IIRC in the all motor and forced induction forums. The stock system is *supposed to* take the air from the valve cover, but most people will find, especially with boosted and higher compression engines, that it comes out all avalable holes. My motor put out a lot running it up to 10k regularly.
KrewOf-1photos
Southern California
Apr 30, 2011 08:36 AM
1320fuel.com
Northern California (Sales)
Jul 17, 2010 09:22 AM
R1
Oct 10, 2006 10:09 PM
2tone_93gt
May 3, 2006 03:04 PM
